E-Class (W211) 2003-2009
1997 e320 cold starting problem
Old Nov 27, 2008 | 11:51 AM
jahman's Avatar
1997 e320
Hi geltelmen, i'm new to the forum. i have a 1997 E320 which has a cold start problem. i have to crank the engine two or three times for about ten seconds before the car will start. when the car starts, there is a strong fuel smell. It run well once started, but if the car is turned off and sit for thirty minutes or longer you have to crank the engine a couple of times before it starts. any help will be greatly appreciated.
Old Nov 27, 2008 | 12:00 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
You have a W210. Try that forum for better answers.
Old Nov 27, 2008 | 01:25 PM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
Sounds like a leaky fuel injector. You probably need to replace one or more of them.
