Ipod kit. HOW DOES IT WORK???
Set COMAND to Aux and then you can control playlists, songs, etc via steering wheel buttons and see the titles in the multifunction display (dashboard)
The MB system is truly retarded. However, I understand there is a system by Denison? which replaces the disc changer with an iPod kit that will indeed show everything on the Comand.
Unless you are very comfortable disassembling the car, I would not recommend the installation. It is time consuming at best. The dealer should be able to do the installation for you.
I don't recall what I paid for mine - I think it was in the $250-$300 range for the Mercedes iPod Integration Kit for the dealer, without installation.
True?
Steve
No ipod control at all via the simple glove box aux in plug and no iPod charging either.
So with the Ipod integration, would the Ipod just sit inside the glove box plugged into the 3.5mm aux jack? How well do the controls on the steering wheel work for controlling the Ipod and how good is the display on the on the instrument cluster? I'm going to buy a used '07 E350 and trying to decide if it's worth finding one with the Ipod intergration. Would love to use my ipod, if the interface is worthwhile
I have had both on my car (MB IPod Integration and the Dension Gateway 500). They both have their Pro's and Con's. I paid close to $500 for the Dension. Several months ago I found the MB IPod Integration on eBay for like $120 and I just had to buy it to try it. For that price? Why not!. I have not seen the MB IPod on eBay again, it was one of those rare occurrences (in case you are wondering
).I don't know what year is your MB so, I will tell you about mine. I have a 2003 E320. I got the EURO COMMAND (which plays DVDs
). I installed DENSION 500 myself. Took me like 2 hours since it was the first time for me taking apart my precious Mercedes. It was not that hard, but then again, I love to work on cars and installing stereo on cars. I was able to control the IPod from both the COMMAND and from the Steering Wheel. I had some minor problems with not being able to access some of the IPod Menu options. I did not mind that much since most of the time I just like for the system to Shuffle Songs which I was able to select from the limited MENU options I had. The cool thing is you were able to see the Song Titles both on the COMMAND and on the Dashboard.I got the MB IPod Integration several months ago. I installed it myself. It took me like 1/2 a day since there are wires that need to run from all the way in the trunk (Main Unit) to the front (near glove compartment). The kit came with a CD that had very detailed documentation on how to install it. I have to say you have to be pretty handy since you have to remove a wire from a connector without messing it up so, you have to be careful when doing it. With the MB IPod Integration I have the same Menu options as the IPod, the only drawback is that you do not see anything on the COMMAND nor you can control the IPod using the COMMAND buttons. Everything has to be controlled by the Steering Wheel buttons and the Dashboard Display. I went to the Mercedes Dealer since I read that SUPPOSEDLY a software upgrade would take care of that but they told me that it was not true, that the MB IPod Integration was designed to work with the Steering Wheel only. Also, you need to have had the phone option activated (or coded) by MB for the buttons to work correctly, it least that is what it says on the documentation. I did not have any problems with that since I already had the phone activated since I have the Bluetooth Puck and base (the Dealer did it for me, for a price of course).
I am honestly going to go back to the DENSION Gateway 500. I like to be able to control the IPOD from both the Steering Wheel and from the COMMAND and to see the Song Titles in both places. Right now I rarely use the IPOD MENU options since it takes too much pressing the Steering Wheel buttons to navigate to those options. I just like to play music randomly but be able to skip songs from both the Steering Wheel and COMMAND when I want to and to see the Song Titles in both places.
That is my personal take on both.
Again, that is my personal experience and opinion.
Oh, I also forgot to mention, the DENSION what it does it fool the system into thinking that is communicating with the 6 CD Changer Unit. This means that the 6 CD Unit will not work if you have the DENSION connected (not that you will need it or miss it if you have all your songs on your IPod
). By that I mean that you will not be able to play the CDs from the Unit.
seems to be the simple solution for less than $100
http://blitzsafe.com/catalog/mercede...8/cat_376.html
