E-Class (W211) 2003-2009
TPMS
Old Jan 7, 2009 | 04:46 PM
MB211's Avatar
2005 E500, 2011 ML350
TPMS
Can the TPMS be activated on an 05 E500----I am looking to use the "cheap" version that only monitors wheel speed (no sensors)----??????
Old Jan 7, 2009 | 08:54 PM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
Looking at SDS it appears that it can, but I don't have one to try it on since mine shows the actual pressures.
Old Jan 7, 2009 | 09:15 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Yes one can program the (BASIC) TPMs that uses abs signal
Old Jan 8, 2009 | 11:14 AM
lkchris's Avatar
'10 CL550, '12 GL550
No additional parts required?
Old Jan 8, 2009 | 11:16 AM
MB211's Avatar
Where in SDS is it----Control units---?----adaptations---....
I assume my cluster does not have the "!" indicator for tire----It will just show the check pressures and "tire defective" light in white or red on center IC display?
Polar Bear's Avatar
No. It calculates the pressure based on the delta of the rotation of the tires and if there is a sudden change.
Old Jan 8, 2009 | 11:17 AM
Polar Bear's Avatar
I will have to look. I have to step out right now but can post later today with the answer.
Old Jan 8, 2009 | 01:06 PM
MB211's Avatar
I believe it takes wheel speed variance between both sides----if both tires are low the light will not idicate-----if you pick up a nail and one tire goes low it should display?
Old Jan 12, 2009 | 04:58 AM
mbz4810's Avatar
08 CLS550 Diamond White 09upgrades
Red face Passive to active
I got my W219 with regular TPMS... wonder if SDS can turn it into an "active" TPMS (where I can see individual # on all 4 tires) without any hardware added...
Old Jan 12, 2009 | 08:51 AM
Polar Bear's Avatar
The system that tells you the actual pressure has sensor mounted next to each tire on the car to receive a radio signal from the pressure sensor located in the rim. There is no way for the car to determine the pressure without this hardware. It can only monitor if there is a significant change in pressure by the rotating speed of the tire and give you a generic low tire warning.
Old Jan 12, 2009 | 10:02 AM
SDS will only set programs / change settings
You will need a Wire harness/sensors x4/control unit and a LOT of labor to have Active TPMs
It can be done but its not a cheap mod
Old Jan 12, 2009 | 11:24 AM
philfna's Avatar
GL350-Bluetec P1
How does one activate the basic TPMS?
Old Jan 12, 2009 | 02:23 PM
Barry45RPM's Avatar
2015 ML 350
Some dealers are willing to activate it using their computers to alter the programing of the cars computer, as these cars are programmed differently for different countries and different model years.
Old Jan 14, 2009 | 10:59 AM
MB211's Avatar
I set "tire loss warner" as PRESENT in CGW. I know have the "re-activate tire monitor" option in the cluster-----I will try to verify it works later....
Old Jan 14, 2009 | 01:36 PM
Polar Bear's Avatar
That should do it. I wonder what will happen if I set that on my with the TPMS High feature...
