phone connection comand
It is not standard.
It is not standard.
so the car has got the phone wiring in.
have just found what i think is the end of the wiring loom under the carpet 2 cables .
one looks like an aerial and the other a 10 core cable could this be it.
they have been cut off.
The MB phone system does usually use an antenna cable and a 10 wire harness but the W211 should not use a separate console for the phone (some older models did). Sounds like it had an after market phone kit.
Was the cradle at the rear of the armrest? Also, if it was the standard install but now they have cut the wires that may be an issue ... not sure how far back you would need to go to replace the cut wires.
