Front Air Baffle
I have a problem that I need some advice on with my W211. I have a 03 sport with the pano roof and parktronic. A few weeks ago I noticed that when I started the car in the morning I could hear a noise about eveyr minute or so that sounded like the front cooling fan was nicking something, this would make the noise for a few seconds and then stop, then after a minute or so it would do it again, over and over etc. I took it in and had MB check it out and they told me there is a flap that opens and closes in the front end and that it was broke and hitting the fan when it would open and close, they said it needed to be replaced. I told them I would bring it in the following week to have it done since I had purchased an extended warrenty through them. The service writer told me she wasn't sure it would be covered but would check. I dropped the car off Tuesday morning and picked it up that evening. When I got the paper work I read through the work performed and this is what it said.
"C/S when vehicle is at idle sounds like a fan is rubbing. Check and Advise."
UCC Warranty
"Performed checkfound air baffle for ft bumper noisy. Cant get part. Need to reprogram and perform wire repair.
Performed wire repair and recoded car. No noise after repair. Left Air Baffle in the open position"
Part# 211-505-07-30 Air Baffle $43.50
labor $332.50
Now I asked the service writer what this means and she said the part to be replaced is no longer available from MB and that MB suggests just leaving the baffle in the open position, according to some service bulletin MB put out. I think this is BS myself and told her as much. The car is 5 years old, I find it hard to believe that 1) MB had discontinued the part and 2) MB simply says to leave it in the open position and disconnect the wire.
What is this baffle for, why does it open and close? MB engineers designed this part on the car for a reason, now all of a sudden its not needed? It makes sense to me that in the cold mornings it would stay closed until the car is warm to help with the heat inside the car? Since my car has the ability to keep the car warm for 30 minutes after turning off the car, wouldn't leaving this door open cool the car faster so my nice option no longer works as well as it used to?
Any comments and advice would be greatly appreciated guys, thanks.
Note air baffle 2115050730 replaces original 2115000116 (see attachment).
I cannot give a definitive answer as to why MB decided to remove this feature seems to me the shutters could have been adequately maintained with cleaning/lubrication.
