E-Class (W211) 2003-2009
problem
Old Feb 4, 2009 | 11:45 PM
merc687's Avatar
Mercedes E350
problem
today wen i wz going bak home i opened the truck with the remote and all the lights in trunk were working fine...and then i closed it . After that i started the car. and then after few seconds i saw that there are 3 malfunctions (2 license plate lights and brake light) . i got off my car and then in order to check i was trying to open the trunk but i couldnt. to make long story short, My 2 licence plate light, brake light, all the lights in the trunk and on top of that i cannot open the trunk with the remote and i can't even open it from the inside.
so what went wrong. i have no idea...is it the fuse...
if yes then is it possible i can change it by myself.
thank you
Old Feb 5, 2009 | 10:57 AM
MB211's Avatar
2005 E500, 2011 ML350
Age and mileage? Could be as simple as a broken wire in the trunk harness.....Could be as bad as a faulty rear sam.....
Old Feb 6, 2009 | 09:59 PM
merc687's Avatar
Mercedes E350
thank you mb211. and you are right, the wire was broken . now everything is fine.
Old May 8, 2009 | 02:08 AM
W210's Avatar
2000 W210 E55->2003 R230 SL500->2004 W211 E55->2007 997TT+2007 E63->2010 GLK350->2012 E550 4matic
Exclamation broken wire causing lack of power in trunk
How long did it take to fix the broken wire? I'm afraid I am having the same problem.
Wish it's simple enough to fix ourselves.
