Lowering 07 E550 without changing springs?
thanks!
First things first you have airmatic (air suspension) so springs are out of the question. Do a quick search on lowering methods with airmatic, i.e. washer method, drop links, RENNTECH module, STAR...
Also, try the search button on the menu above... there's a wealth of information available on this site but you'll have to look for it.
1 The dealer will do it..Several dealers will NOT do it
2 The Tech knows how to lower the ride height via The SDS aka Star
AND, you will need to get an allignment as well.
EDIT: Reading the post again, it will depend HOW MUCH lowering you do. If it is only .5 inch, I dont think you will need it, but then again, I dont think 1/2 inch is what you are looking for and that is what I was assuming on my response. Just wanted to be clear.
I plan to only lower via SDS and I don't think you can lower it more than what the car is at, at highway/freeway speeds.
So I should be ok because the car is naturally at that level on the freeway?
Thank you, sir. Lots of time and lots of money.
This is just a guess.
PS I'm also located in Vancouver.
