E-Class (W211) 2003-2009
Is there anything wrong with my Car
Old Feb 13, 2009 | 01:56 AM
Taimoor's Avatar
03 E320
Hi, I am from Vancouver, Canada. I have a 2003 E320 Sedan.
"I feel" the car doesn't drive smooth. I mean nothing wrong with engine or suspension or the tires but i feel something is up with transmission.
The car kinda slows down a lot when i lift my foot off the gas in 1st and 2nd gear.
I want it to just keep moving without slowing down like this.
It feels like a manual car, when you lift your foot off the gas in low gears and the car slows down. Kinda like the engine brake thing.
Is that normal?
I asked mercedes rep and he told me its normal. I mean de didnt check it though.
Do you guys feel the samething, is it related to software or is it a hardware issue.
I know the best way is to take it to Mercedes, but my car is no longer under warrenty and they will charge like $100 just to take a look. So i want to get a little more information from you guys first.
Old Feb 13, 2009 | 09:48 AM
Clinton Horn's Avatar
2003 E320
My (2003 / E320) does that as well. It does not upshift while the car is decelerating in 1/2 gears. Most domestic cars will upshift when coasting down hills. M-B does not. I like it. It reduces breaking and unnecessary wear on the tranny. I don't think you have a malfunction.
Old Feb 13, 2009 | 11:07 AM
Barry45RPM's Avatar
2015 ML 350
I assume you recently got this car and its not an all of a sudden type of thing. When these cars are "cold" they hold gears longer before upshifting. Because it is a 7 speed (unless you are AWD) 1st gear is very low. Lifting my foot off my accelerator while in 1st slows the car down just like in a manual trans car... no coasting. So I assume its normal for your car too.
Old Feb 13, 2009 | 11:43 AM
jbec.keane's Avatar
2013 E350
The 2003 E320 is a 5-speed auto. At least mine is.
Old Feb 13, 2009 | 03:30 PM
konigstiger's Avatar
'71 Pinto
CH is correct however, if this is happening on level surface have the Engine Control Unit (ECU) software updated using latest flash disc per DTB P-B-07.00/28f FEB04 (only applicable to MY03 211) by dealer or independent.
What you may be experiencing is hesitation “as if” caused by two-footed driver (i.e.: driver depresses accelerator and brake pedal at the same time).
Old Feb 13, 2009 | 03:34 PM
Taimoor's Avatar
03 E320
Thanks guys for telling me that. It took a lot of burden off my mind.
Also I feel similar deceleration when driving at higher speeds.
Although not nearly to the same extent but it surely doesn’t coast.
Do you guys experience that too?
Old Feb 13, 2009 | 03:37 PM
Taimoor's Avatar
03 E320
ICIC, ill call them about it right now.
