Serviced at Dealer, Now Have Issues...
was 1996 MB C280, now 2007 MB E350
In Dec08 I bought a 2007 E-350 sport w/ 32,000 miles. It's in great condition, but since its new to me and still under warranty I thought I'd take it into the dealership for an oil change and new brake pads.
The dealer changed the oil ($120) and brakes ($600), but also did some free warranty work that included rear engine port gaskets (oil leak), replaced cylinder magnets (??), and a recall repair (not engine related).
several weeks after the repairs the following issues began:
1) When initiating braking (immediately after starting to depress brake pedal) the transmission up-shifts, causing the engine to lose compression and sending the car lurching forward (very dangerous at a time when the car needs to be stopping). After slowing down more the car begins the normal down-shift cycle required during braking. This creates very dangerous, jerky braking. I almost have to plan for the lurch forward in timing my braking. It appears to be an electronic/transmission issue, and I've thought about reseting my electronic shifting memory (i.e. turn steering wheel from side to side). Any ideas on what is causing this and how to fix.
2) My engine has started to have a ticking/chugging noise during idle. It reminds me of my Dad's old MB turbo-diesel. "tickachugga-tickachugga-tickachugga" . My old '96 C-280 started to have the same sound at around 115,000 miles, but my '07 E-350 only has 35,000 which in my mind should still be puring like a cat. Any ideas on cause and remedy?
Even though the car is still under warranty I'm dreading the idea of having to take it back to the dealer, since I have severe trust issues and the car always seems to come back from the dealer worse than it went in. Any help is much appreciated!
Thanks,
Sideshow76
Thanks,
Sideshow76
Received 4,446 Likes
'71 Pinto
2011 BMW X5d, 2011 Nissan Leaf and Kubota L39 Tractor!
I had the ticking issue after changing the oil (myself) on my 07 E350. The sound was coming from the oil filter canister. I opened the canister up and reseated the filter. The sound went away.
I can't help you on the tranny issue.
Neil
Neil
Thanks for the advice, and I look forward to more.
My issue isn't with the specific MB Dealer (as the guys are actually pretty nice), but I just lament taking my car to dealers in general. If I can fix it myself I'd prefer to do so, and thanks to all your sage advice I just might be able to.
Thanks!
Thanks!
