Dyno'd my car today...
My car is bone stock minus AMG mufflers... best run was:
235.6hp @ 4846rpm
297.80tq @ 3067rpm
I had some issues at first completely forgetting about putting the car in dyno mode. Once I got it figured out it was 3 runs on the Dynapack. Horsepower seems a tad bit low and torque seems 20 lbs too high.
All in all a good day and nice to meet some fellow Vancouver MBZ enthusiasts![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
I'll post my graph tomorrow at work (no scanner at home)![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
Has anyone dyno'd with a Dynapack? If so, how do they compare with Mustang/Dynojet?
235.6hp @ 4846rpm
297.80tq @ 3067rpm
my W211 E350 4Matic did 191 whp w/ a cat-back exhaust I'd love to get it up to your stock 500 hp that'd be great, not that far off either. Good work thanks for the info.
235.6hp @ 4846rpm
297.80tq @ 3067rpm
235.6hp @ 4846rpm
297.80tq @ 3067rpm
Numbers do seem off. Did you dyno in 5th gear? That's the final drive gear on our 7sp cars. Also, area these SAE corrected numbers?
**EDIT**
Forgot you had the 2003 with a 5speed. What gear did you dyno in?
They dynoed in 4th...
I'm not sure if it's SAE corrected numbers but i'll try to find out. To be honest I was a little skeptical of the Dynapack which requires the removal of the rear wheels. This isn't your typical drive on, strap down and run it setup.
Does my graph look normal?
**EDIT**
Actually I wonder if 277-278 tq is the right number? According to factory specs we achieve 339 crank torque at 2700 RPM...
**EDIT**
a car
LOL I was say not so nice. Jikjak dynoed at 455 +/- HP at the wheels with his CLS55 that same day. It became pretty obvious that i should stick with all show no go ;-)
Yeah, I get the same inferiority complex when I go to dyno days and track events. I try to make myself feel better by telling everyone that I have the the quickest N/A E500 in the country. That is, until someone proves me wrong.
Porsche Macan S SportDesign / Ex M-B's: 11 & 10 & 06 E350's, 02 S500
That does seem like major drivetrain loss in the HP area. IMO it would make sense to get those numbers if your car was a 4-Matic? ![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
Also those torque numbers do seem abnormally high. Some Dyno's just work differently than others and show different results.
Has anyone Dynoe'd a non 4-Matic E350? A 268 HP car should be dynoing at over 225 HP to the wheels.
