E-Class (W211) 2003-2009
Access through firewall
Old Apr 20, 2009 | 09:46 AM
DrNizmo's Avatar
2004 E500
Hi all
First post here. I did a search and wasnt able to find much so I thought I would ask.
I need to run a cable from the engine compartment of my 2004 E500 and I am looking for suggestions on access points where I can drill through. Are there any empty panels or grommet points that I can use or is it just going to be a crap shoot and pray I dont nick something when I come through? It needs to be big enough to fit a CAT5 cable with a RJ45 plug on it
Old Apr 20, 2009 | 12:08 PM
Benz-O-Rama's Avatar
Originally Posted by DrNizmo
Hi all
Well, I'm not quite sure about placement. But to minimize risk, you can cut the RJ45 head off, and drill a much smaller hole then re-terminate the cable end. Very easy if you have the know how and an Rj45 crimper.
Now I must ask. What the hell are you connecting?
Old Apr 20, 2009 | 06:58 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
Ya, I'm thinking the same thing when I saw CAT5 and RJ45.
Old Apr 20, 2009 | 10:54 PM
TMAllison's Avatar
09' E320
Look around/under the brake booster. There are usually a couple of rubber grommet covered holes you can access.
