E-Class (W211) 2003-2009
07 E550 pumping noise
Old May 4, 2009 | 01:39 PM
tpliquid's Avatar
too poor now
I did a search and it does not seem like a airmatic noise?
This sound is like a "pump" and fan noise coming on and staying on for around 30 seconds. sometimes it stays on for 10 or 5. It also sounds like a fan has been turned on.
The sound comes from the front driver side. you cannot hear as much from passanger side.
any input will be aprreciated
Old May 4, 2009 | 03:12 PM
konigstiger's Avatar
'71 Pinto
It may be the Airmatic compressor that is located on the front driver’s side, wake-up (monitors height and load changes) occurs with any one of the following inputs: key activation, any door activation, trunk lid activation, park brake activation, and stop lamp switch activation.
Old May 4, 2009 | 03:15 PM
tpliquid's Avatar
too poor now
stop lamp switch activation meaning when i hit the brakes?
it comes on throughout the whole drive. From home to work and work to home is around 20-25 minutes. is that normal for it to be on the whole time?
Old May 4, 2009 | 04:49 PM
lovnlife's Avatar
2007 E550
do you hear the noise when you are inside the car with windows up?
Old May 4, 2009 | 04:53 PM
tpliquid's Avatar
too poor now
i hear it with windows up. when i roll down the windows i cannot hear it.
The noise usualy starts right after i start driving.
Old May 4, 2009 | 04:54 PM
tpliquid's Avatar
too poor now
Old May 9, 2009 | 11:06 AM
mcleantmw's Avatar
2003 E500 Benz & 2015 BMW M235ix
As previously indicated, if it's coming from the left driver's side, it's the AirMatic pump for the suspension. I had mine replaced recently under the warranty and the new one even makes the pumping noise........operates periodically. It's kind of annoying but not much you can do about it other than there's a Technical Bulletin to install a dampening device that helps a little.
