E-Class (W211) 2003-2009
Need help with A/C
Old Jun 15, 2009 | 03:58 PM
takitoz71's Avatar
2004 mercedes E320
Need help with A/C
So i was coming back from the casino this past saturday and my a/c just shut off automatically. When i tried pushing the A/C off button, it started flashing slowly. The fan just blows but i cant turn on the A/C itself. I can turn on the defroster and everything else but the a/c, just blows hot air. Does anyone know why it does this? do i have to take into to the dealership for service? Why does it flash, is there a way i can reset it?
Old Jun 16, 2009 | 03:42 AM
Diesel Benz's Avatar
There must be a fault, I guess you have to have the car diagnosed. Could be as simple as a sensor but it could also be a leak and low on refrigerant.
Old Jun 16, 2009 | 01:45 PM
Carlosj148's Avatar
03 E500 & 16 E350
no or low refrigerant
mine did the same and it was becuz the refrigerant was low. under warranty I went to stealership dye is not covered for leak check. It came out to something like 275.......but it is a meatlocker now
Old Jun 16, 2009 | 02:02 PM
konigstiger's Avatar
'71 Pinto
Warranty does cover approved tracer dye for leak test at no cost per DTB P-B-83.00/97a all models air conditioning not cooling / leak test using fluorescent dye.
Old Jun 16, 2009 | 02:21 PM
KYBENZ's Avatar
2011 E350 4 Matic,1994 C220,1965 Mustang, 2005 Kawasaki Vulcan 1600
That's bad info as approved dye is covered.
Old Jun 16, 2009 | 03:27 PM
takitoz71's Avatar
2004 mercedes E320
k cool guys guess all set up an appt with the dealership.
