E-Class (W211) 2003-2009
I need 22 more HP - Whats the easiest Mod that wont affect engine life
Old Jun 21, 2009 | 04:28 AM
007_e350's Avatar
X166 gls450 2017
I'm not a fan of forced induction, in my opinion it will REDUCE engine life & pull Mpg numbers down (increase in compression ratios that aren't taken into account by manufacturer will increase wear n tear)
Here's what I have in mind:
- Any suitable Intake mod (non oil based so MAF doesnt go bad)
- Exhaust headers to ease back pressure
Anything else ?
Old Jun 21, 2009 | 11:28 AM
Benz-O-Rama's Avatar
Anything else ?
If you just add headers, you'll lose HP. You'll need an ECU tune to take advantage of the extra airflow. Remember, back pressure is your friend on these cars. I lost horsepower when I added headers, removed my secondary cats, and deleted the resonator with a X-pipe. But, after L.E.T. worked their vodoo on my car, I got it all back plus more.
To gain 22 whp on a 350 engine is not easy nor cheap. But, if you must have 20-25 hp, you'll need at the very least, an ECU tune and extensive exhaust work. Add a set of lightweight forged wheels, and you should be able to squeeze 25 ponies out of her. Gonna cost thousands to get there though.
Ask me how I know.
You might be able to try a variant of the VRP python tube intake. Completely removes the OEM airbox and straight plumbs the intake to the front of the car with a set of cone filters. Not sure what you'd gain, if anything, on a 350 engine.
On an aside, I have the lightweight wheels for sale right now.
Currently, I own the quickest naturally aspirated E500 on record.
