E-Class (W211) 2003-2009
Coolant Level Sensor Location?
Old Jul 4, 2009 | 04:02 AM
Tariq's Avatar
S500 W223 2021
Hello guys,
Actually I have problem with the water level in the coolant tank, its shows the display warning to check the water lever, however once i check the tank it shows its full , I assume it has some faults with the water level sensor, I wish to know how to replace it and where its located.
Hope someone who faced the same can share me some of his experience.
Regards
Old Jul 4, 2009 | 05:13 PM
konigstiger's Avatar
'71 Pinto
Originally Posted by Tariq
Hello guys, Actually I have problem with the water level in the coolant tank, its shows the display warning to check the water lever, however once i check the tank it shows its full , I assume it has some faults with the water level sensor, I wish to know how to replace it and where its located.
Washer fluid level sensor part #2205400045 (for comparison shopping, parts.com $10.64) PM your email address and I will forward WIS for washer reservoir.
Old Jul 13, 2009 | 04:52 PM
Tariq's Avatar
S500 W223 2021
Thanks for the comments, well I already changed the sensor but the warning still saying when I switch the ignation "Check Coolant Level" Note that the water coolant level is physically Ok and I replaced the sensor with a new one but still its warning me!
my email is tariq.shj@hotmail.com
Thanks any way
Regards
Old Jul 13, 2009 | 05:53 PM
'71 Pinto
I apologize, previous recommendation for “washer fluid” sensor was incorrect. In rereading your original post the water level switch to “coolant” expansion tank (#170 in diagram) is part 22054540024 (for comparison shopping, parts.com $10.92).
