Rotora Big Brake kit on CLEARANCE!
Former Vendor of MBWorld
Hey guys,
There's a set available under clearance pricing on ROTORA BBK for your E-Class W211 (exc 4matic)
Features:
-Rotora billet aluminum alloy 6piston racing calipers with sequentially sized piston bore sizes engineered to each specific vehicle.
-Rotora billet aluminum hat with �floating� disc assembly to reduce heat related stress and unsprung weight.
-Rotora 2 piece vented heat treated directional vane disc system to improve airflow/cooling under severe braking. Slotted or drilled & slotted oversize discs (355x32mm) to ensure equal heat dissipation and increase thermal capacity while relieving the disc and brake pad surface free of excess debris.
-Rotora ceramic formulated pads designed for extreme street and track application with high co-efficient of friction and high temperature fade resistance.
-Rotora DOT compliant stainless steel braided brake lines to improve stiffer pedal feel and prevent brake hose expansion.
-Rotora carbon steel (SC45) mounting brackets (depending on application) and hardware.
8piston:
6piston:
Clearance Kits available in:
Front- 8 piston 15" / 6 piston 14"
Rear- 4 piston 15" / 4 piston 14"
RED Calipers with DRILLED/SLOTTED Rotors
**Will not fit 4matic
PM/EMAIL/CALL ME for pricing!
Features:
8piston:
6piston:
It was getting ready to go into production and right at the last minute Race Technologies asked me if I had spoken to a shop that was local to me that they deal with. I spoke with him and upon further inspection it became evident that the regular brake kit for the W211 front can be fitted to a 4matic with some adaptation to the mounting bracket and so forth. The company is called Azavedo Motorsports down in South Jersey. Give em a call, the extra $1500 surcharge for the custom Brembo app wasn't worth it once I found I could adapt the Brabus/Alcon kit which is much more in sync with the obvious theme of the car. So, there you have it.
