E-Class (W211) 2003-2009
A couple of problems
Old Jul 18, 2009 | 02:59 PM
pilot_alex's Avatar
2003 E320
Hi guys! I own a 2003 E class and have a couple of problems with it. I took it to a independent dealer he scanned it and came up with following problems.
a) My check engine light is on. Car idles very rough feels like misfire, if code is clear it runs OK. After check engine light turns on again and car does same thing. The code for it was.
Major Leak in Purge System
I'm suspecting there is air going into the engine. Are there any weak spots i should check.
B) SBC unit i have read light "reduce braking... " The code for that comes up as SBC unit service threshold reached. My guess is under warranty they have ti replace this thing.
C) I forgot what SAM modual this was the code was " component e5/2 is faulty or lead has open circuit" no clue what that is.
D)Component e40 has short circuit or open circuit. I think this could be my fog light which is burnt out.
Thanks for the help guys i appreciate it.
Old Jul 18, 2009 | 06:06 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
SBC is under warranty for 10 years/unlimited mileage. Your good with that one, dealer should replace.
