E-Class (W211) 2003-2009
2004 E500 ignition problem!
Old Jul 19, 2009 | 11:18 AM
junusung's Avatar
e500
Old Jul 19, 2009 | 12:17 PM
E500 AMG Sport's Avatar
Did it have problems starting when the engine was hot and then after cooling off it was able to start?
You stated that it wouldn't start when you got it home, how long was it parked before you tried starting it again?
Old Jul 19, 2009 | 12:20 PM
junusung's Avatar
e500
10 minutes
Old Jul 19, 2009 | 08:55 PM
In that case, it sounds like a bad Crankshaft Position Sensor. It's a common issue with all Benzes. It may actually die on you while you are driving, so get it fixed quickly!!!!!
Do a search. You can buy them online (Ebay, etc.) for about $40-$50.
It's about a 10 minute job so if you are capable with tools, do it. Otherwise the dealer will rob you.
You will need a E8 torx socket.
PM me if you have more questions or need help.
Gary
Old Jul 19, 2009 | 09:13 PM
junusung's Avatar
e500
Thank you so much for your help!
I will definitely contact you if I have any questions.
Thank you!
Old Sep 18, 2009 | 11:21 AM
rostov's Avatar
2016 GLE 450 Coupe
Thank you!
Hi Junusung,
Did it work? I guess it is time for me to replace mine - I had this issue twice in 2 weeks time frame. Also I get Check Engine light after that for a while…
Dealer price for the sensor $163.02.
Old Sep 18, 2009 | 01:34 PM
Diesel Benz's Avatar
Originally Posted by rostov
Hi Junusung,
The original poster just explained "When I turn it to iginition, it just make sound and won't start". It isn't clear to me if the engine cranked or not, it could have been just a starter solenoid problem if it was the starter motor making noise but not cranking the engine. If the engine did crank, then it would likely be the CPS sensor.
Old Sep 18, 2009 | 02:33 PM
rostov's Avatar
2016 GLE 450 Coupe
In my case it does crank, I also hear the fuel pump when turn ignition on. And since the CPS is common issue, I think this is it and will change it anyway.
And something tells me that original poster had the same symptoms.
The only question is – is the sensor goes bad or just dirty?
Old Sep 18, 2009 | 06:58 PM
rostov's Avatar
2016 GLE 450 Coupe
Ok... Where is it located? the sensor...
Old Sep 19, 2009 | 11:20 AM
rostov's Avatar
2016 GLE 450 Coupe
Just had sensor replaced - will see what happens.
Yes, is you know where it is - 15 min. Just had to cut some strips to get those wires out of the way. Buy the way, somebody say it is easier doing it from the bottom - don't see how...
Old Sep 19, 2009 | 11:34 AM
It is not about dirt, the anyway work from a magnetic field, the new ones having hall sensors (which should survive forever, it is really odd that the CPS failure is so common).
