2009 DVD in motion
https://www.tvandnav.com/index.asp?P...ROD&ProdID=344
I therefore see no reason why the module advertised would not work as it is placed in between the communication path.
I am curious how it may affect the accuracy of the ETA feature or calculation(s) of the navigation. Since if my theory is correct the navigation unit will no longer have accurate traveling speed information from the vehicle and has to rely on the satelite position each time to calculated the correct ETA or off-road travel. If anyone knows how these add-ons really work and/or if any noticable navigation performance issues are apparent I would certainly be interested.
Switching the speed signal off would affect navigation in the sense that it would have to rely on GPS measurements which are not that accurate e.g. when approaching a turn and specifically if satellite view is temporarily blocked etc. But the device here appears to support on/off switching from the steering wheel. If you are using navigation, you can always switch off VIM without physically removing the device.
