E-Class (W211) 2003-2009
moonroof/sunroof, opens 1 inch at a time
Old Aug 15, 2009 | 12:05 PM
ataie's Avatar
2007 Mercedes SL550 Sport
I have to press the moonroof button about 10 times to get the roof to open completely. each time it's pressed it goes back about an inch and stops. is there something that needs to be programmed, like holding the buttons down etc to get it to do the one push open?? thanks 05 E500 sport
Old Aug 15, 2009 | 12:46 PM
madelko's Avatar
Veteran: Army
2017 GLC 300 4Matic
this happened . . . . .
This happened on my 99 and to correct whatever went wrong, I tried the reset function: With the roof closed, open the rear vent feature and hold it up for five seconds, at first it seems it is all the way up (open) but then it will go up just a little bit more and then it is reset.
Worked for me -
Old Aug 15, 2009 | 12:49 PM
ataie's Avatar
AWESOME....... that got it done. it's working now. thanks you
Old Aug 19, 2009 | 02:44 PM
Roehl's Avatar
2004 MB E-500 & 2000 Honda Accord Coupe
This is awesome. All the issues with problem solved should be stickied.
Old Aug 19, 2009 | 03:35 PM
dsm2925's Avatar
W211
Agreee
Old Aug 28, 2009 | 03:04 PM
blueacc333's Avatar
C300
I got a C300.. and having the same problem.... I tried to do the same process in order to reset the setting of the moonroof... but it didn't work for me... It works fine while opening.. but not closing... it just stop and go... I have to hold the button at all time... Any advises????? thanks
Old Aug 28, 2009 | 03:36 PM
konigstiger's Avatar
'71 Pinto
I recommend cleaning/lubricating the rails covered under warranty if out of warranty PM email address and I will forward instruction sheet.
Old May 15, 2011 | 03:04 PM
Solid1's Avatar
This worked on my 04 E500 in about 10 seconds!
Old Apr 1, 2012 | 10:21 PM
bjp1874's Avatar
E63 AMG
Just did the trick on my 2007 E63. Thanks!
Old Oct 13, 2013 | 12:34 PM
SA187's Avatar
2005 E500
Worked for me -
THANK YOU!! worked for my 05 e500
Old Oct 13, 2013 | 02:36 PM
homeofstone's Avatar
2011 E63, 2011 Hyundai Genesis 4.6 v8, 2013 GMC Denali XL, 1965 Ford Mustang, 2005 Merc. E500
I found that a complete reset for all switch positions is necessary sometimes. with roof open all the way back hold the switch for opening for 10 sec. then close and hold for 10 sec. then flip up and hold for 10 then down and hold for 10. This worked on my 2005 E500 w211.
Old May 31, 2014 | 09:53 AM
MBAlexandria's Avatar
2004 C230
Thanks, worked for me, too
Worked for me -
Thanks, I had the same thing happen to me this morning, and the reset worked for me, too. Thank you for the tip!!
Old Nov 29, 2018 | 07:52 AM
Onyxthecat's Avatar
06 E500 4Matic Wagon
Just had this happen in my 06 E500 and this worked. Thanks
Old Aug 9, 2019 | 02:21 PM
jmgincs's Avatar
I looked every where to try and fix this and your solution worked perfectly, thank you.
Old Sep 19, 2019 | 01:35 PM
austin94's Avatar
2001 E320, 2010 E350 Sedan, 2009 E350 Wagon, 2014 E350 Coupe, 2015 ML 350
Mine on my 2009 E350 only opens, closes, and vents up a little at a time. I had to push the button probably 10-15 times to get it to open/close all the way. I tried resetting it and it's still not working... maybe I'm dense and doing it wrong... Do I have to open it all the way and then hold for 10 seconds? then close all the way and hold for 10 seconds, then open vent all the way and hold for 10 seconds? I've tried it so many times doing it different was to no avail...Any advice?
Old Sep 19, 2019 | 03:31 PM
'71 Pinto
Try reset several times if it fails on first attempt. Cannot reset at all, consider cleaning/lubricating. Do not use WD40, Plastilube multi-purpose lubricant works well.
File Type: pdf
Old Sep 23, 2019 | 09:06 AM
LexBrett2's Avatar
2007 Mercedes E550
You disconnected the battery at some point and now the sunroof needs to be resynched.
Old Jun 26, 2020 | 07:15 PM
wilcur02's Avatar
2008 S550
This worked for me as well. Thank you!
Old May 1, 2021 | 03:23 PM
Jarrod Hagenman's Avatar
2007 Mercedes E320 Bluetec
Thank you!!!
Worked for me -
I figured with my luck this trick wouldn't work. I was wrong. It worked! In the past month I've had to replace the intercooler & all the seals/gaskets & the turbo. I only got 127k this year. I miss my 85 300D
Old Sep 15, 2022 | 08:04 AM
Buttsnet's Avatar
2004 E500
this happened . . . . .This happened on my 99 and to correct whatever went wrong, I tried the reset function: With the roof closed, open the rear vent feature and hold it up for five seconds, at first it seems it is all the way up (open) but then it will go up just a little bit more and then it is reset.
Worked for me -
Thanks so much. Worked like a charm on my 2004 E500. I signed up for this forum just so I could recommend this posting.
