E-Class (W211) 2003-2009
hood ding
Old Sep 4, 2009 | 06:51 AM
MBTenn's Avatar
E350
hood ding
How much to fix irritating gravel ding (size: one quarter of pencil eraser) on 2007 E350 hood? Thanks
Old Sep 4, 2009 | 07:15 AM
pinebaron's Avatar
07 E320 Bluetec
It really depends on if the complete hood requires respraying. I had a stone bounce off the hood in my first week of ownership. MB paint shop said the complete hood required repainting to color match; instead I filled the chip with several layers of OEM paint and got by.
Old Sep 4, 2009 | 07:39 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Is the paint broken? If not you might see if PDR can remove it. Otherwise you need to repaint the complete hood or if you don't mind, a little dab will do ya. That will, at least, get rid of the primer/paint mismatch.
Old Sep 4, 2009 | 01:49 PM
Roehl's Avatar
2004 MB E-500 & 2000 Honda Accord Coupe
Is it a ding with a chipped paint? If it is just a ding with no paint damage, it is probably $50. Paintless dent removal usually cost that much.
Old Sep 4, 2009 | 01:51 PM
taylor210's Avatar
02 E320 Blk, 09 E350 Blk
If the paints/Clear coats are not cracked, You can simply do PDR and will run around $175 to 200 per panel. I've called the mobil pdr guy to fix my door ding and came out perfect and smooth...
Old Sep 4, 2009 | 03:44 PM
MBTenn's Avatar
E350
Looks like a microscopic cracked egg, and slighly indented--so maybe paint/clear coat is cracked; MBTenn
