E-Class (W211) 2003-2009
MICROPHONE REPLACEMENT?
Old Sep 17, 2009 | 02:39 PM
MANOS75's Avatar
e350
DOES ANYONE KNOW HOW TO REPLACE THE MIC IN THE REARVIEW MIRROR AND IS IT VERY DIFFICULT?
Old Sep 17, 2009 | 03:16 PM
i_am_amused's Avatar
2004 S55 (SOLD, miss it every day), 2009 GL550
I'M SURE SOMEONE, SOMEWHERE, KNOWS HOW, BUT YOU'LL HAVE TO ASK IN A whisper
I've seen a write-up on this, and do not recall the steps as being very difficult.
there is one (maybe two) microphone-related TSB for W220s, so maybe there is one for your W211 and you can get a free replacement
Old Sep 17, 2009 | 04:24 PM
MB211's Avatar
2005 E500, 2011 ML350
a. TSB does not mean FREE replacement, it is a Techincal Service Bulletin to help diagnose an issue
b. Replacement is easy, remove mirror and install new mirror .2hrs labor and $1000 in parts.
Old Sep 17, 2009 | 08:46 PM
I guess you missed the word "maybe"...
It's definitely at a dealer's discretion to repair a known fault without charge, and TSBs arise from known faults. It's quieter, cheaper, and less unpopular and brand-damaging to do such repairs through TSBs
And like I said, the steps involved are not complicated
Old Sep 17, 2009 | 09:05 PM
bobgodd's Avatar
2004 E55
To dislodge the mirror pull down on it really hard.. You'll think you've broken it when it comes loose, but it has a strap in there to keep you from damaging anything. Once it's hanging down, you can pull apart the dome lamp assembly and I believe the wire for the mic is brown and white.
Old Sep 18, 2009 | 02:10 AM
jimbo1mcm's Avatar
All Diesel Fleet !1983 240d stick,2005 E320 CDI Midnight blue, 2005 E320 CDI, Desert Silver, Kubota
Microphones bad?
I think there are 4 microphones in the mirror of my 05 CDI. Does anyone know how the tech checks if they are good or bad? A forum member wrote that after they were replaced, his bluetooth quality improved greatly.
Old Sep 18, 2009 | 12:44 PM
dw8083's Avatar
2013 E350 4MATIC
If you sound muffled on the phone system in the car, the mics are bad. I've learned that this was an epidemic problem on 04-05 W211's. Maybe other years as well. In either 06 or 07, MB when to a completely new design with 2 mic's instead of 4 to resolve the problems.
The individual mic's can be replaced. Warning! the rearview mirror housing is fragile to take a part, but easy to reassemble. Odds are high the small plastic tabs holding the mirror's case together will break while taking it a part.
Ask MBenzNL about how to do this.
-David
Old Sep 19, 2009 | 11:39 AM
Mackhack's Avatar
How do you know if the mics are bad and how much do they cost?
Old Sep 21, 2009 | 01:36 PM
dw8083's Avatar
2013 E350 4MATIC
Used mirrors cost between $150 to $350. A new MB mirror is $1000. The challenge in buying a used mirror is knowing if the mics are working correctly.
The only diagnostic process that I'm aware of, is to use the mics with a cell phone to determine voice quality.
-David
Old Sep 22, 2009 | 08:19 PM
MANOS75's Avatar
e350
SOMEONE GAVE PART # FROM PARTS.COM NOW THEY ARE GONE
