H&R cut springs Camber Question
07 E350 sport
Could not locate answer on forum hopefully you guys could answer.i installed h&r springs on w211 and noticed gap in front.Nasty..Took it to alignment and with 4 crash bolts was sitting at -.9 degrees..I cut half a coil to even drop but havent took it to alignment shop.Looks like an inch drop was added.Question is what is an acceptable camber that the w211 can ride on with out uneven tire wear..Does anyone know the stock factory camber on w211 2007 sport or any w211s..Please help cause Im debating on if I have to get a kmac kit ontop of these front camber bolts..Thanks Bros
