E-Class (W211) 2003-2009
Windshield Washer Replacement Question
Old Sep 29, 2009 | 10:31 PM
klpete's Avatar
I have a 2004 W211. It has the stock "two stream" windshield washer nozzles on the hood. I don't like the way they work. I've noticed that newer MB's have a broad spray nozzle. Does anyone know if any of the 2005-2009 W211's have this kind of washer nozzle? If so, is it interchangeable?
Thanks,
Kirk
Old Mar 29, 2012 | 07:14 AM
Gersh320's Avatar
E320 & X166
Thanks,
Kirk
Did you ever change yours out. I hate the way mine works, but the 2008 I drove the other day works amazing!!!
Old Mar 29, 2012 | 11:25 AM
foreyes's Avatar
2002 G500, 2007 CLS 550, 2018 GLC 300
The nozzle openings get clogged up with residue (calcified minerals, etc.) over the years. You can use a fine point needle to clean the nozzles. When I cleaned out the nozzles on my 03 E500, the spray pattern was much more broad with excellent coverage. You can also adjust each nozzle up, down, left and right to fine tune the pattern and avoid overshoot (while you have the needle inserted into the nozzle, you can "steer" the nozzle position). I have done this many times over the years with all of my vehicles.
Old Mar 29, 2012 | 07:12 PM
Barry45RPM's Avatar
2015 ML 350
Just remember to aim them almost a couple of inches higher than you would ideally want the strike to land because when you are moving at speed, wind will keep the spray lower down on the window than you aimed them , and the fluid stream will creep up the glass, pushed up the glass by the wind.
Old Mar 29, 2012 | 07:57 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
i also have realized a problem with mine and don't like they shoot out. i will also try this at home soon.
