E-Class (W211) 2003-2009
enabling DVD in motion with STAR
Old Oct 7, 2009 | 11:55 AM
masterross's Avatar
w211 '04 Avangarde
Exclamation enabling DVD in motion with STAR
Hi guys,
Can you assist me to enable DVD in motion for my W211 COMAND APS?
The firmware is 21.090 (latest one).
I heard that this can be enabled via STAR DAS but now exactly?
Thanks in advance!
Old Oct 8, 2009 | 02:15 AM
wampa's Avatar
E500 & ML500
Originally Posted by masterross
Hi guys,
Thanks in advance!
Just to confirm that you do have a euro comand?
Old Oct 8, 2009 | 04:40 AM
masterross's Avatar
w211 '04 Avangarde
Hi,
Yes sure my Comand is EU (ECE)
Old Oct 8, 2009 | 09:20 AM
samo1's Avatar
Mercedes Benz E320 W211 2004
Here are the required steps for activating Video in Motion:
ENGINEERING MODE Menu:
Press Mute + Endcall + Service (all together and hold for 5 secs)
ENGINEERING MODE Extended Menu:
Press # * left cursor arrow (all together and hold for 5 secs)
The new menu items are:
• Dr.Dist – Driver Distraction
• RegCod – Region Code
• Backd…- Backdoor
Driver Distraction menu:
handbrake locked
gear shift in P
speed 0 km/h
speed 10 km/h
general picture lock
Un-selecting these gives you 'Video in Motion'
Note:
The following software update for the headunit will remove access to the engineering menu:
SW-Rel 15.130 Build - SW Year/Week:05/51
I.e, This SW release removes the access to to the DrDIST, RegCode and Backd "hidden menus" so if you have access to multi region DVD's and "Video in motion" you will lose these features if you upgrade your headunit)
Old Oct 8, 2009 | 11:16 AM
masterross's Avatar
w211 '04 Avangarde
• Backd…- Backdoor
handbrake locked
gear shift in P
speed 0 km/h
speed 10 km/h
Note:
Thx.
But probably u didnt read my first post:
Which means eng menu not accessible anymore
Old Feb 18, 2011 | 06:37 AM
ospdk's Avatar
W202
Stardiagnostic
Any one know the steps to enable this from DAS ?
Old Feb 18, 2011 | 06:48 AM
masterross's Avatar
w211 '04 Avangarde
Yes. I've done it:
http://www.digital-kaos.co.uk/forums...19-more-89343/
Old Feb 18, 2011 | 07:46 AM
ospdk's Avatar
W202
Developer
Thanks, where in DAS do you enetr developer mode ?
Old Feb 18, 2011 | 10:05 AM
masterross's Avatar
w211 '04 Avangarde
Your DAS needs to be activated/registered with developer key.
Old Feb 18, 2011 | 12:19 PM
samo1's Avatar
Hi guys,
Thanks in advance!
This method works with my US command (latest firmare):
Firstly go to the language menu by pressing SERV key, then the System soft-key, then the Lang. soft key. Now hold down the 'phone-hangup' key, the small key between up and left on the arrow pad, and the Audio key. This should enter Engineering mode.
Old Feb 18, 2011 | 07:09 PM
wampa's Avatar
E500 & ML500
just curious, but you have a 2003 US COMAND with DVD in motion?
I heard those are pretty rare
Old Feb 19, 2011 | 01:53 AM
samo1's Avatar
No, my command is US version (no DVD).
That method just puts command in Engeneering Mode with new firmware
Old Jun 5, 2011 | 10:55 AM
catacam66's Avatar
mercedes E280cdi(w211)
it works. but how enter in secret menu????? (dr_dista.etc)
Old Jun 5, 2011 | 11:39 AM
lkchris's Avatar
'10 CL550, '12 GL550
Here's some help: be sure to advise your insurance agent you've made this modification.
Old Aug 17, 2011 | 11:01 PM
superman7's Avatar
2004 E500 4Matic
Great, it works. but how to enter in secret menu? I did "*" + "#" but didn't work...
Can you reset the MOST from there?
Old Jan 22, 2013 | 04:49 AM
brockmang's Avatar
C350cdi AMG
does it work on a clk w209
Old Feb 11, 2013 | 11:13 AM
jkspoff's Avatar
Mercedes Benz E320 diesel
Thanks for the advice, after a quick 5 minute adjustment, my comand now allows MP3 and DVD playback in motion. Great when the kids are watching, its common sense not to view it when driving !
Old Feb 19, 2013 | 03:27 AM
Jacek123's Avatar
W211 320 CDI '07
Hello Guys,
i´m from Poland and i got a w211 from 2007 with NTG1 and i wanted to activate watching DVD while driving. The engereering mode doesnt work, because the firmware is the newest one, so i have to activate it with the Star Diagnosis.
Can someone help me how to do this ?
In the comands menu there are 3 options
1st : watching while standing still : on
2nd: watching while driving slowly(i guess 6km/h) : on
3rd: watching while driving: off
So i have turned it into on and ended and i have tried, but it still doesnt work..?
What could i do ? Do i hjave to switch to an other coutnry mode or sth?
Thanks in advance
Jacek
Old Feb 19, 2013 | 04:16 AM
masterross's Avatar
w211 '04 Avangarde
SHould be like this:
Old Feb 19, 2013 | 11:36 AM
Jacek123's Avatar
W211 320 CDI '07
Well,actually it is like this, but it doesnt work..?
Old Feb 19, 2013 | 04:08 PM
masterross's Avatar
w211 '04 Avangarde
Hi,
Sometimes SDS reads all as enabled.
You should change it to disable then save it.
Reboot module or lock/unlock the car.
After this enable it again and lock/unlock the car
Old Feb 19, 2013 | 05:46 PM
Jacek123's Avatar
W211 320 CDI '07
Well but there is no other option i would have to change ? Like country code or sth?
Old Feb 20, 2013 | 04:46 AM
masterross's Avatar
w211 '04 Avangarde
No. No need.
I saw similar problem like your on my friend w211.
First time SDS reads parameters all were Enabled, but cant watch in motion.
After I did described above all was ok.
Old Jun 18, 2013 | 11:32 AM
marko68's Avatar
W202 Esprit ; T-S204 PACK AMG
• Backd…- Backdoor
handbrake locked
gear shift in P
speed 0 km/h
speed 10 km/h
Note:
which button is the service? Is it possible to make a video and explain. please?
Old Aug 19, 2014 | 05:35 PM
philippe406's Avatar
Mercedes E220
Smile Unlock DVD in motion
Hi all
I'm from France, my car is a mercedes E220 (2007). I have a DVD player but it is not working when the car is in motion. Of course I've read a lot on this forum and with google as well. It seem like with firmware version 21.090 there is no any solution to access the IM ?
I just have access to the advance menu (not the secret menu where we can change the DVD settings)
My questions are:
1/ Do someone here found a way to downgrade the system
2/ Can't we add some additional hardware (like an adaptor) to get the original unit to work in motion.
Thank you for your answers.
