E-Class (W211) 2003-2009
Got my E55 Yesterday!
Old Oct 28, 2009 | 07:57 PM
alextaylor29's Avatar
2004 E55 AMG
20 years I've been aspiring to own a Merc and finally I've attained it. It's a low milege 2004 model and the power is stunning!
Of course I have to start modding it now so I was thinking of air filters initially going with K&N, apparently it's +15 HP if you replace both filters.
Odd question, I popped the hood and I couldn't find where the air filters are located? How do I get to them and remove them?
Anyway couldn't be happier, it's a stunning ride! I call it a "Banker's Hot Rod."
Alex
Old Oct 28, 2009 | 08:47 PM
ajmal21's Avatar
Benz e500 2004
Originally Posted by alextaylor29
20 year I've been aspiring to own a Merc and finally I've attained it. It's a low milege 2004 model and the power is stunning!
Alex
hi Alex
the air filter is on top of the engine. as you can see the two big hose coming int to both side of the engine and going to the back to teh back of the engine. you need two airfilter
Old Oct 28, 2009 | 10:39 PM
dlav06's Avatar
Dodge Challenger Hellcat Widebody, Porsche Cayenne, International Scout
Congrats on your new purchase and welcome to the fam. You're about to embark on the jouney of a lifetime.
Enjoy!!
Old Oct 28, 2009 | 10:54 PM
220S's Avatar
Porsche 991S, Cayenne S, 1972 BMW 3.0CS E9 Coupe
Congrats!
Now get yourself over here: https://mbworld.org/forums/w211-amg-81/
Old Oct 28, 2009 | 11:39 PM
M-bENZ's Avatar
Corrolla
Alex
The filters are inside this airbox. When you take it out flip it over you'll see it.
Andy
Old Oct 29, 2009 | 11:48 AM
F1Bobby's Avatar
From: People's Republic of California (Southern Region)
C55 AMG, CLK550
Congrats!
Old Oct 29, 2009 | 02:11 PM
2004 E55 AMG
Wonderful thanks guys. I just use the standard allen wrench to remove the airbox and access the filters correct?
I drive 100 miles every day to and from work so it's been a thrill to have such a fantastic ride upgrading from a Dodge Durango.
Old Oct 29, 2009 | 04:40 PM
SPNJHockey's Avatar
07 E350 4Matic / Sport with P1
Most - if not all - of us E350 owners are jealous of your 8 cylinder.
Old Oct 29, 2009 | 04:42 PM
M-bENZ's Avatar
Corrolla
are you really ? 100 miles everyday ? wow you should buy the extended warranty...im serious.
Andy
Old Oct 29, 2009 | 04:51 PM
AMGfan's Avatar
06 SL65 / 97 993tt /11 Suburban/ 2012 GTR (AMG è la mia Famiglia la Bestia è la mia protezione)
Alex
Congrats on the purchase...
1. Like others have said...you need two.
2. 15hp is pretty optomistic...but upgrading filters still should help.
3. Best bang for your buck is a stage 1 product (Kleeman, VRP, LET, etc...) which is usually bigger pulley and ECU tune.
4. Heat soak is a biatch so prepare for that...(upgrade the HE and make sure your IC pump is operating properly)
5. Unsprung weight is something to think of...(lighter wheels and rotors)
6. Drive it around for awhile and get used to it then mod...that way you have a solid baseline butt dyno to work with (and get a real baseline dyno).
Enjoy and be safe...
PS If it is relatively low miles (below 50K...mine is 04 and only has 33K), I would suggest getting an extended warranty, too. At the very least, find a independent certified ASE MB mechanic in your area. Luckily, there are several in my area that have left MB to start there own shop...usually a 1/3 to 1/4 savings in labor.
Old Oct 29, 2009 | 07:07 PM
2004 E55 AMG
All,
Yes great advice since I live in Phoenix AZ and heat soak will be an issue. It's cooling down now but will be a challenge in the summer.
Regarding the extended warranty yes I got that as well, 5 years or 60K miles on top of what I have and only a $50 "co-pay" for most everything or $75 at the dealer. I got the car through Car Max and it is low miles 30K range.
On the IC (Intercooler?) I have no idea what the means and perhaps you could link me to your recommended "Heat exchanger" upgrades?
Thanks again.
Alex
Old Oct 29, 2009 | 08:30 PM
AMGfan's Avatar
All,
Thanks again.
Alex
Alex...I am talking about the intercooler pump. You can go to your MB dealer and get the upgraded Bosch pump (the older ones tended to have intermittent failure...you feel the car lose power) or go with a CM30 Johnson pump. For most, the IC pump failure was intermittent and threw no codes and sometimes taking it to the dealer and getting it fixed was a crapshoot. I guess they got so many complaints that is why they upgraded the Bosch pump. I went with Johnson pump for my E55 and SL65 because of the reliability factor and at the time I changed it out of my E55 the Bosch upgrade was not available.
The heat exchanger upgrade kit I got was through VRP but you can get it through Evosport or LET (I believe)...it is usually accompanied with a upgraded IC pump and larger heat exchanger core. There was a Ebay seller that was selling what seemed to be a possible upgrade heat exchanger but I don't have personal experience with it.
Jon
Old Oct 29, 2009 | 08:54 PM
Mackhack's Avatar
Did I read correct? 15HP more with upgraded air filters?
Old Oct 30, 2009 | 02:40 PM
2004 E55 AMG
Thanks very much. Yes regarding the HP improvement with K&N Filter's that's what they listed but realistically I"m sure it's much lower. Still it will help as I'm sure the standard cloth filters aren't as efficient.
Regarding the pump I just found what you're referring to here: http://autoperformanceengineering.com/html/jabsco.html Should I go with the 12v or or 24v?
I've already encourtered this issue but thought I was doing something wrong on the computer was lowering the engine output because I hammered it a few times in a row. (Hey I just got the thing!)
I'll but the new pump today via the link but just need to know if I should go with the 12v or 24v.
Thanks very much!
Alex
Old Oct 30, 2009 | 04:57 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
sick ride. congrats
Old Oct 31, 2009 | 12:40 AM
2004 E55 AMG
Oh by the way got my plate picked out...ready...?
"GONEIN5"
And the beauty is GONEIN4 is also available but I'll have to do some mods first to "earn" that plate.
So summarizing I plan to do the following mods right away based on your collective recommendations:
- K&N Airfilters
- IC Pump upgrade
- Heat Exchanger
- Remove the rubber beneath the wiper blades that traps heat in the engine bay
All told this is $500-$700 bucks which isn't bad. If somebody here could recommend the heat exchanger and point me as to where to buy this I'd greatly appreciate it!
Lastly if there are any other, easy, straight forward, faily inexpensive "must do" mods for a new E55 owner I'm all ears.
Thanks very much.
Alex
Old Nov 6, 2009 | 08:40 AM
dsm2925's Avatar
W211
pics?
Old Nov 6, 2009 | 12:35 PM
F1Bobby's Avatar
C55 AMG, CLK550
Yeah! Pics?
Old Jun 18, 2012 | 02:54 PM
robusa's Avatar
Shopping for: CLK500or CLK55 or SL55 or SL500 or C43
hows the E55 holding up?
hello! its been a few years since this post.
just wandering hows the E55 holding up?
Old Jun 18, 2012 | 03:59 PM
NorseWagon's Avatar
2019 E-450 Wagon
Wrong forum, you'll probably find him over on the W211 AMG place, (If he is still alive) this is the plain vanilla W211 chapter (E-320, E-350, E-500 and E-550)
Old Jun 18, 2012 | 05:25 PM
djrabbi's Avatar
EQS AMG, E53 AMG, GLE63s
i think he sold it?
Old Jun 18, 2012 | 05:54 PM
Barry45RPM's Avatar
2015 ML 350
Originally Posted by djrabbi
i think he sold it?
LOL... that would make it "GONEIN3"
Old Jun 18, 2012 | 08:57 PM
Mackhack's Avatar
Hey man you're still around
Old Jun 18, 2012 | 09:37 PM
NorseWagon's Avatar
2019 E-450 Wagon
Yup, still kicking.
Now in San Francisco, going home tonight..
Stll got the wagon, but the aftermarket warranty is running out in a few months so I have to make a decision..
Too bad MB does not make an E-Wagon with the diesel engine, would buy one in a flash.
How are you? Married with bambinos now?
Old Jun 18, 2012 | 10:18 PM
gaazmon's Avatar
LOL
