E500 2004 or E350 2006
I would like to know which one you'd go for? performance wise are they close or is there a big difference???
for info the E500 (306 bhp) is silver/ black with full AMG package 18"rims, panoramic sunroof and full option
the E350 is black / black, and normal options.
both cars have low mileage.
10x for ur help
There is a huge power difference. The 500 has a little over 300 hp with about 339 torque while the 350 has 268 hp with 258 (i think) torque.
Is either a CPO or does either of them come with extended warranty from MB?
10x for the info... well the 500 has only 43k miles certified and the 350 like around 70k. both are under 1 year warranty!!! thats y i find it hard to choose.
well both have 1 year warranty. I know that the 06 will be a better choice but perhaps those few pics can give you a hint y im so lost between the two cars. I dont have pics of the 350 but its because its a classic one...
For me, a heavy tank like an e class, I would say v8 or bust. If you want to be in the ball park of highschool kids in their mustang gts then i say 350
but then again i do all my work myself and own a e500
i say drive them both and pick the one u like better not the one others say
10x for ur help
Also, the later built 04s (mine was 02/04) were better off than earlier built 04 models.
Additionally, u're getting the AMG package which is eye candy, but was a $4K option back then and is actually pretty rare on a V8. It looks simply amazing. And its not an E55"wanna-be" because it has its own distinguished AMG dual tip mufflers.
Airmatic is second to none. But $$$ to repair. (Not sure if you get the awesome 7 speed auto in the 2004 model).
The V8 has excellent braking with 4 piston calipers up-front. Don't know about the V6...
After all that, you should be wary of the 2004 reliability issues.....
U may want to hold out and look for a 2005 E500.
OR consider a W210 E55
- 350hp, 380ish torque. EDIT - I just looked at your pics. Is this really an E500? Its debadged, and it does not have the original AMG 18" rims which came with the AMG package (at least in 2005). Notice how mine are in my sig. (I have the 2005 model). Also notice the quad mufflers - Def. not part of the original AMG Sport Package. The package included dual AMG mufflers. If this is indeed an E500, the previous owner made the effort to make it look like an E55, but be advised this is not the original AMG package from the factory.
Make sure the mufflers upgrade was professionally installed without any hacking around the bumper. No doubt the car looks stunning.
Is this an MB dealership?
Good luck!
The V8 has excellent braking with 4 piston calipers up-front. Don't know about the V6.../QUOTE]
Ya, the 500 V8 is a great engine. Massive torque. You can really feel that push.
Yes, you get the 7 speed on 2004 E500. E320 doesn't have 4 piston calipers, instead 2 and not the brembo style look either. However, the E350 might have 4 piston I believe if it has the AMG sport package, but again not sure.
That car is debadged, so its hard to tell if its RWD, and even if its a V8. Hopefully the OP is looking into these 2 issues as we speak,, err. I guess type/read?
I also noted the "AMG" engine cover. No way that's standard on an E500 or E350.
To the OP, make sure this car indeed is a V8. It may be, but double check, and it seems that the previous owner went to lengths to make give it the AMG look. The car also looks lowered, which means the suspension has either been lowered electronically, or by using "the washer method" which can be found here somewhere in the forum.
If I am right, I would be wary of this car. Not trying to scare you, but please make sure the car is what it is claiming to be - an E500. And find out if the suspension was modified, and how. (U sure those are 18's, and not 19's?) - that would explain the dropped look....
Good luck!
Gaazmon, shame on you! Note the quad mufflers too. That's not standard factory equipment either.
This car is fishy by far
