E-Class (W211) 2003-2009
05 E320 diesel leaking
Old Dec 1, 2009 | 05:31 PM
fool32696's Avatar
05 E320 CDI
I've been smelling diesel fumes when I exit the car just about since I bought it in August 09. I thought it was normal. I haven't been able to find any drips anywhere that I parked. Last night I backed in instead of pulling straight in the driveway (driveway slants away from house). Today I noticed about an 8in round spot that smelled like diesel. I'm guessing that it has just been collecting in the belly pan. It seems to be originating in the engine compartment judging by a quick look under the hood this evening. I'm going to start pulling covers tomorrow and break out the flashlight. Any ideas on problem areas or where to look first?
Jimmy
Old Dec 1, 2009 | 11:03 PM
stickygreen's Avatar
'97 E320
check fuel lines - usually the culprit
Old Dec 2, 2009 | 12:10 AM
fool32696's Avatar
05 E320 CDI
I peeked in with a flashlight later and it does look like it's dripping from a metal fuel line going into the block. Could it just be a loose connection? Is there a seal that could go bad? Is it dangerous to work on with engine off and if so, what's a safe way to release the pressure?
Old Dec 2, 2009 | 12:13 AM
saffrontiger's Avatar
W211 2005 CDI, X166 2013 350 BT, 997.1 2008 C4S
Fool, I had the same issue with mine many years ago. I wrote extensively re this issue. Primarily the fule lines are leaking and early late 2004 build (MY 2005 CDI's) were known to have apoorly fitting clamp. There aferr there was revised DTB to this effect. Hope this helps. Call your dealer and have them run your VIN for possible DTB's. Good thing is after this fix I have not had any other issues beyond a bad EGR after 110,000 miles.
Jay
Old Dec 2, 2009 | 09:49 AM
fool32696's Avatar
05 E320 CDI
I cut off the old hose ends and put on new clamps and the problem seems to be fixed.
