E-Class (W211) 2003-2009
Buzzing noise in dashboard
Old Dec 11, 2009 | 02:59 PM
Robbie3015's Avatar
2004 E500
In my '04 E500, without a HK stereo, standard 6-disc changer w. Comand, recently a sort of buzzing / humming noise comes out of the big triangular vent opening on top of the dashboard. It sounds like a blown speaker, but it disappears or gets louder, depending on the settings of the heater / AC controls.
Also when I start the car in the morning out of that same area I hear sometimes a light creaking (adjusting the doors in the heater system), that is sometimes followed by a rather loud single pop. Only once. I don't know if these things are related or not, just trying to give as much info as possible.
In case I do need to get under that triangular vent to clean things up, has anybody ever done that and if so, how do you get there?
Many thanks upfront.
Old Dec 12, 2009 | 03:42 PM
hatplus's Avatar
2006 E-350
I have a 2006 e-350 HK sound system.
I had a blown speaker sound depending on radio station and volume
Later I found that My speaker was torn.
After I replaced the speaker( Desktop computer speaker - same size $0.00 cost)
sound was normal. No more blown sound.
Original speaker is $ 130.00 . I didn't want to spent that money for small speaker.
Copy below title and paste at seach
You can find that how to remove center(Triangular) grill.
I hope you have same problem like mine. Good luck!
l@@k at this! write up: how to remove & replace center channel speaker and grill
Old Jan 5, 2010 | 05:05 PM
Robbie3015's Avatar
2004 E500
Thanks! That was easy. I bought the original replacement part at the dealership for $50.00. I pried the panel off by pushing the little clips down and pulling the vent towards you, as stated in the thread. Two torques and a wire connector and re-install. About 20 minutes worth of work. Like I have a whole new sound system.
