E-Class (W211) 2003-2009
E500 4MATIC Front Differential Oil Change
Old 12-13-2009, 10:19 AM
zszalay's Avatar
05 E500 4M
Hi, does anyone know where I can find the drain plug of the front differential or how I can drain the oil ? It seems as if we have only found the filler plug. If anyone has any info on this that would be greatly appreciated. Thanks.
Old 12-13-2009, 02:14 PM
JoeVal's Avatar
C350 Elegance
Smile
Check with your dealer, but I seem to have read that there is only one hole for draining and filling in models associated with the 722.9 transmission, and there is a replacement lubricant and draining pump combo equipment at the dealers -it can otherwise be done with a common boat servicing pump and funnel and there should be a sticky somewhere around.
It takes a special gear oil for the AWD, use the right one only.
Old 12-16-2009, 06:14 PM
zszalay's Avatar
05 E500 4M
Thank you for your help ! I really appreciate it.
Old 12-22-2009, 02:26 AM
007_e350's Avatar
X166 gls450 2017
I thought differential only exists for rear wheels - the front ones are taken care of at the transmission, so a transmission oil change would do the front diff as well...
I just did the rear diff oil change yesterday, have to tell you the car feels much more torquey at lower rpms, I used Mobil 1 75w-140
Quick Reply: E500 4MATIC Front Differential Oil Change
