Akebono Brakes and wear sensor
On a brighter note, MB's and Porsches are so nice to do brake work on compared to many American cars. No caliper pull, just take the pads out the top and put the pins back in. 15 minutes a wheel on the Benz and I can do a 911 in 10 minutes a wheel because the pin has a clip.
I recently replaced front and rears with Akebonos and realized only rear pads came with a pair of wear sensors. I was able to use one for the front pad from the rear set since my car uses only one sensor each on passenger side wheels only.
If you cross reference the pads they show a fit across multiple makes and models. That's why it gets screwed up.
