E-Class (W211) 2003-2009
List of Service Items done so far
Old Jan 11, 2010 | 12:24 AM
007_e350's Avatar
X166 gls450 2017
I've 506xx miles on the clock, so far I've serviced the following - What else can be done to the car ?
1- Oil Change Mobil1 0w-40 (41k) (Dealer did Service G)
2- Oil Change Mobil1 0w-40 (46k) DIY
3- Transmission Oil & Filter Change (48k) from the Dealer
4- Differential Oil Change (50k) DIY
5- Headlamp bulb change (49k) DIY
6- Air Filter Change (48k) DIY
7- New Spark Plugs (48k) DIY & Serpentine Belt change
Upcoming items requiring service;
8- CV boots rear developed cracks (I'll try myself)
9- Brake Oil Bleeding (I'll try myself)
10- Radiator coolant Flush (risky DIY ?)
12- Oil Change at 51k
13- Fuel Filter (I have no clue how to do this one, need help)
14- Passenger side muffler has a joint that was leaking some water droplets - might corrode down the road (DIYable ?)
15- Crank Position Sensor - I heard this can get you stranded on the road, so I'll just swap it out (I'll try myself)
Can someone recommend anything else
thanks
Old Jan 11, 2010 | 01:35 AM
tigerlee's Avatar
1999 E320
fuel filter
Hi all.
How to replace the fuel filter on (1999) E320. Right my car had almost 90k miles on it. Do you know when my car need to replace the the water pump.
Thanks.
