E-Class (W211) 2003-2009
Wipers - what CAN be adjusted?
Old Jan 23, 2010 | 06:17 PM
Vik888's Avatar
2008 E550, 2012 GL450, 2014 GLK350, 2015 S550, 2020 GLC350e
I'm curious what can (i.e. parameters) be adjusted with the wipers on my 08 E550?
Its been raining quite a lot lately in SoCal and I noticed that when the wipers are on, they leave a slight "streak" behind them that fairly quickly fades away. It is almost like you're wiping with Windex that you see a little streak that then evaporates before your eyes.
It isn't a huge deal. These are still some of the best wipers I've driven with (although I loved the "V" wipers on the old Benz's) but just curious if thats normal or not and if I should take it to the dealer to get them adjusted.
Old Jan 23, 2010 | 07:09 PM
konigstiger's Avatar
'71 Pinto
If you decide to bring the vehicle in the wiper arm angle can be checked https://mbworld.org/forums/3433379-post4.html
Old Jan 24, 2010 | 02:37 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
can an indy shop do this, since i don't want to go to the dealer since mine is out of warranty???
Old Jan 24, 2010 | 02:45 PM
'71 Pinto
Yes however to properly adjust angle, they will need to access WIS sheet and have adjustment tool 211589022100 on hand.
Old Jan 24, 2010 | 03:27 PM
gaazmon's Avatar
thank you. i'll see if the shop i take it to can get a hold of one of these or if he has one.
Old Jan 25, 2010 | 04:04 AM
Vik888's Avatar
Thanks ..
So I assume what I'm seeing with mine isn't normal and should be corrected?
