E-Class (W211) 2003-2009
cross drilled/slotted in front only?
Old Mar 11, 2010 | 08:01 PM
dannieboiz's Avatar
08' S550, 04' E320 4matic, 03' Acura TL-S 6 speed, 1968 Vespa P150
Would it be weird if I replaced the fronts with cross drilled and the rear with OEM rotors? I already have a pair of new rotors for the rear but I need to replace all four.
Old Mar 11, 2010 | 08:50 PM
220S's Avatar
Porsche 991S, Cayenne S, 1972 BMW 3.0CS E9 Coupe
Why would it be weird?
The front brakes are the ones that get overheated and benefit from being slotted, drilled, and vented. All that weight and forward weight shifting during hard braking. It's also why the front rotors are larger (on performance brakes.)
Old Mar 11, 2010 | 10:30 PM
SPNJHockey's Avatar
07 E350 4Matic / Sport with P1
...and that's how the '07 Sport comes.
Old Mar 12, 2010 | 04:07 AM
petep86's Avatar
205, 211 V8 4M, B7 /RS4, e30 ///M3
alot of cars come wit front cross drilled and the back regular.
Old Mar 12, 2010 | 08:37 AM
WRC7732's Avatar
2005 E320 CDI
Just more function over form. From and asthetic perspective, fronts and rears look better. Although when my brother did his, he did the fronts first and the rears later. You spent so much time ooh'ing over the fronts that noone ever noticed the rears.
Old Mar 12, 2010 | 09:06 AM
Clinton Horn's Avatar
2003 E320
I don't have drilled rotors on our MB but I have read several members complaining about aftermarket drilled rotors warping very quickly. I am not suggesting that all do because too many vehicles use them successfully. They are pretty heavy so even if you get them by mail order with a guarantee, you will likely suffer return shipping if they fail. I think the consensus is if you are going to use drilled, buy OEM
