Crank Position/Speed Sensor
Basically car wouldnt start, i reset it from battery and waited 30 mins. and it did start. Took it to a merc expert and he immediately said it was this sensor. $400 bucks later and just 1hour to fit it seems to be fine. Have searched and found heaps of people have this issue on older models but wondering if anyone has had it on their w211? If it is a common problem then maybe preventative maintenance is to do this diy when you can rather than get stuck somewhere.
My car died while running so this could have happened to me on the motorway. Gotta say i love the look, feel and features of my e500 but thinking this car that i spent XX dollars on is that easy to break down and not give out codes for both me or on a scanner .......
Buy a good Star diagnosis tester, then you do not need to complain about difficulties to read codes.
Buying a star dagnostic would have done nothing for me in this case other than a nice fat bill because the codes were cleared when i reset the battery. Anyways your missing the point, im not asking for a code reader or a solution, im simply asking if anyone else in their w211 has had the same issue.
