Please help, how to torque properly - Stages?
06 E350
Hello All,
I am in a middle of replacing the failed ball joints on my E350 and am following the workshop procedures. However, I don't know how to properly torque some of the components.
What is the difference between "Stage 1" and "Stage 2" ?
The torque values differ for Stage 1 and Stage 2 for torquing the ball joint e.g:
Stage 1 = 50 Nm
Stage 2 = 60 Nm(?) - there is a small pictorial here showing some sort of angle/degrees?
Please advise.
Thanks a lot.
J
Stage 1 = 50 Nm
Please advise.
Thanks a lot.
J
04 E500
Evidently these are "Torque To Yield" bolts, in which the bolts are initially torqued to 50 Nm (Stage 1), and the head of the bolt is then rotated through an additional 60 degrees (Stage 2) without any measurement of the torque. If you want to be accurate you can get a torque angle gauge for the Stage 2 measurement, but you can probably eyeball 60 degrees and come pretty close.
If you're interested in how these bolts work, there's a pretty good explanation at http://forums.pelicanparts.com/911-e...oad-bolts.html
By the way, since this type of bolt has already been stretched to the yield point, it should be replaced, and not be reused.
