E-Class (W211) 2003-2009
Changing out Radiator need help - 2003 E500
Old May 21, 2010 | 09:47 PM
jjleonard's Avatar
2003 E500 Mercedes
Have a 2003 E500 with 81K miles and have identified that I have the dreaded A2115000202 old style Valeo radiator which I'm planning on changing out to the new style. Need assistance in finding part numbers and best place to purchase the following:
1) Radiator Hose Seals (upper and lower) - assuming this Benz has them as I think.
2) ATF tube seals (seals for automatic transmission lines into radiator).
3) Any other seals I may need (ie-power steering maybe)
Any help is much appreciated.
Old May 21, 2010 | 09:50 PM
jjleonard's Avatar
2003 E500 Mercedes
This is the information for the pertinent parts that I have
radiator (A2115003120), trans fluid (A001989210319), and mb coolant (Q1030002) - can anyone just verify prior to me placing order.
Old May 21, 2010 | 10:22 PM
Efivehundred's Avatar
06 E55(SOLD), 03 E500(SOLD)
EPCnet has the part number for the radiator as A 211 500 31 02
Passenger side radiator hose seal: A 003 997 18 89
Trans tube seal ring: A 028 997 62 48 You'll need two of them.
You should also get the locking pin for the trans fill cap: A 140 991 00 55
I can't help right now with the fluid part numbers. If you don't have a subscription to EPCnet, you should get one. It's an invaluable resource for DIY, and it's free.
Old May 23, 2010 | 12:25 PM
jjleonard's Avatar
2003 E500 Mercedes
Appreciate your help - have subscribed to parts catalog as well which should definitely be helpful in future.
