Fuel vacuum system vs. check engine light
Now after 1200 miles light comes back on again. I checked things myself first. Sensor is still good, no cracks. There is a tiny bit of fuel (looks old and oily) in the recess, but that might be from the repair, I do not smell anything in the car and I don't hear the vacuum pump anymore. Brought it to the dealer. It has been there now for more than 2 days. The service manager says they get the same fault codes, but they can't find anything, The system seems to be leak proof, car runs great. They are scratching their heads, I am scratching mine. Anybody seen something similar and maybe has some advice here?
EVAP systems are complicated and many technicians dread trying to fix them. Considering valves, carbon cannister, wiring & connections, and all the vacuum tubing, the problem could be anywhere.
When you said that the "sensor is still good", how did you [electrically] test it?
Regards,
paul..
