E-Class (W211) 2003-2009
What torx bit is needed on brake rotor removal for E500?
Old Jun 26, 2010 | 08:48 AM
Todd Edge's Avatar
E55
I went to install new rotors last night and attempted to remove the (1) star shaped bolt that holds the rotors to the hub assembly. I used the torx bit I felt fit snug and it ended up stripping the inside of the bolt. Two questions...
1)What is the correct torx fitting for this bolt
2)How can I get the one out I thoroughly stripped?
Thanks,
Todd
Old Jun 26, 2010 | 01:30 PM
lkchris's Avatar
'10 CL550, '12 GL550
Drill the head off to get the stripped one out.
You really can't hurt anything doing this, as you're replacing the rotor anyway.
The goal is to just get the head off the screw so you can pull the rotor off.
Then with vise grips or pliers turn out the remainder of the screw shaft.
Old Jun 26, 2010 | 08:13 PM
Todd Edge's Avatar
E55
FYI - It is a T30...
I ended up using the next size up and hammered it into the bolt and was able to back it out...
Todd
Old Jun 26, 2010 | 11:32 PM
SPNJHockey's Avatar
07 E350 4Matic / Sport with P1
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
