E-Class (W211) 2003-2009
Electrical consumers switched off ??
Old Jul 18, 2010 | 02:24 PM
parabolics's Avatar
w211 270 CDi
I am getting the Electrical consumers switched off 2 malfunctions message increasingly on my 2002 211 270CDi the heater blower stops and the interior light stops working. If I turned off the ignition and restart the malfunctions clear, the lights and the fan work again for a while then it comes up again after random time intervals ?? any ideas??
Old Jul 18, 2010 | 02:28 PM
Diesel Benz's Avatar
Did you measure the battery voltage from the main and the AUX battery?
This has been discussed a lot before but if the message appears while you are driving, it could be your alternator (regulator) or an issue with the battery control module (I assume the SW update and other recall stuff has been performed a long time ago for this car).
If both batteries are good, the AUX battery relay should be checked.
Welcome to the forum. From your car I assume you are not from the US, you could fill your location info to your profile, it often helps a lot.
Old Jul 18, 2010 | 02:48 PM
parabolics's Avatar
w211 270 CDi
Hi – thanks for the prompt reply ! yes I am in the UK, and yes it happens when I’m driving (usually at low revs, slowing for a junction, although it happened this afternoon at 50 mph on the A34! But why just the heater fan and interior lights?
Old Jul 18, 2010 | 03:37 PM
Are you sure it is just the heater fan and interior lights turning off? Have you tried the rear window heater, heated seats cigarette lighter etc?
You did not comment on the battery voltage, it does sound like the voltage drops too low and the car switches off consumers. You did mention two malfunctions, I'm not sure how it appears at the instrument cluster but it looks like you have passed the first step of consumers being switched off because of low battery voltage (the alternator being not able to provide the current your consumers would draw). Several items get switched off at the first stage and only at the second stage the heater fan speed is reduced (not completely switched off).
The idea is that only important consumers from driving safety point of view are kept active as long as possible.
Old Jul 18, 2010 | 04:33 PM
parabolics's Avatar
w211 270 CDi
All are still working ? - can I check the Bat. voltave on the dash?
Old Jul 18, 2010 | 04:46 PM
Cosinus's Avatar
X218, W169, W451, S205, W415
This is a typical malfuction of an ol battery.
I think, you have to buy a new battery and everything is working right.
You should drive to your MB-dealer ... he knows the right type of battery.
Good luck!
Old Jul 18, 2010 | 09:04 PM
Scambo's Avatar
'13 E550 W4
It could be the Battery Control Module (BCM) acting up causing one battery to drain and lose power to the consumers. Have them check it.
Old Jul 19, 2010 | 03:04 PM
Ronaldk's Avatar
W211 E200 Kompressor
Battery voltage check
Parabolics, you can check the battery voltage in dash, provided you have the 4-zone climatronic aircon system.
This thread explains how to get to the diagnostic mode of the AC:
https://mbworld.org/forums/mercedes-...diag-mode.html
Channel 24 provides the battery voltage.
Old Jul 19, 2010 | 04:06 PM
There is no "the battery voltage" because the car has two batteries. Even if both should have the same voltage when the engine is running, this may not be the case if the AUX battery relay is misbehaving. The cluster or the AC display definitely does not work if one wants to know the idle voltage of each battery.
Old Jul 20, 2010 | 12:56 PM
Ronaldk's Avatar
Voltage of battery
I stand corrected... The "system" voltage is measured and displayed after accessing the correct channel on the diagnostic mode of the AAC. However, if one would disconnect a terminal of one of the batteries, then surely the sytem voltage = the remaining battery's voltage output when the engine is off? One can then reconnect and disconnect one of the terminals of the second battery to get info on the second batteries output.
Old Jul 20, 2010 | 02:27 PM
I stand corrected... The "system" voltage is measured and displayed after accessing the correct channel on the diagnostic mode of the AAC. However, if one would disconnect a terminal of one of the batteries, then surely the system voltage = the remaining battery's voltage output when the engine is off? One can then reconnect and disconnect one of the terminals of the second battery to get info on the second batteries output.
Have you ever tried measuring the voltage either from the AC panel or the cluster when only the AUX battery is connected? You might be surprised.
Anyway a lot easier to measure each battery with a cheap multimeter without disconnecting any cables, the AUX battery relay anyway isolates the two batteries when ignition is switched off.
Old May 16, 2011 | 02:09 PM
bomarhe's Avatar
300TD, 300CD
Hi, I'm getting the battery warning, with engine running, I have 14.1 volts at the main battery. I changed the aux battery, but I'm not getting charge voltage to the aux. Meter reads batt. voltage, 12.8 VDC. I'm thinking relay, but I don't know its location. Anyone out there can point me in the right direction? (2005 320CDI)
Bob
