2007 E320 Bluetec - location of oil drain plug
Unfortunately, it doesn't show definitively the location of the oil drain plug. I am 95% sure that I found a 13 mm black drain plug that is seated in a small black drain pan located just in front of where the transmission mounts to the engine. The trick is that I want to be 100% sure so as to not drain the wrong fluid.
Might someone confirm the drain plug location? The car is on stands with the bottom trim panels off and I'd like to finish the job tonight so the wife can't get too upset!
Thanks in advance.
Regards,
Trevor
Please help.
Thanks,
Trevor
