E-Class (W211) 2003-2009
Enabling backup camera on NTG 2.5 E350
Old Feb 11, 2020 | 08:42 PM
  #126
Brandon Kim's Avatar
2009 E350
Originally Posted by Mackhack
Did you connect and mount the rear view camera already?
OBD.
I’ll clear my over flowing inbox tonight.
Not yet. going to drill/mount and rewire tonight. We can just tap into the back up light right? or would it be safer to use the 12v outlet
Old Sep 4, 2020 | 11:40 PM
  #127
anomadtoo's Avatar
09 E63
Those that have done the drilling of a new camera hole; can I drill in this small spot between the handle and right light circled in my pic? So the camera is more centered.
seeing all these ebay and Amazon cameras ranging from $18 to $50; any recommendations?
thank you all
Old Sep 4, 2020 | 11:45 PM
  #128
Mackhack's Avatar
thank you all
That’s how I did it and 10 years later I regret it. The camera stopped working and I can’t take it out because then there is a hole in the trunk.
I use license plate light cameras nowadays on my customer’s cars.
Old Sep 5, 2020 | 01:04 AM
  #129
anomadtoo's Avatar
09 E63
But they are replaceable easy enough correct?
is there a plate light camera you recommend? I’ve seen a couple but they have the curved edges in front while mine is in back. One Chinese vendor has it style 1 or 2 depending on the shape and you have to specify; so at least that’s good, but not many vendors do that; and I’m not waiting 2 months to get it
thanks Mack
Old Sep 5, 2020 | 01:19 AM
  #130
Mackhack's Avatar
thanks Mack
Wait a few days and I can show you one.
Old Sep 9, 2020 | 01:13 PM
  #131
anomadtoo's Avatar
09 E63
For my E63, I wound up ordering this camera as it had the correct shape for light cover (downward):
Misayaee Rear View Back Up Reverse Parking Camera in License Plate Lighting (NTSC) for MB C-Class W203/E-Class W211/W212 CLS-Class W219 W218 (No. 1 size 2565mm Down Round Edge) https://smile.amazon.com/dp/B07CLB2W..._SUqwFbHW7WR7J
and this module suggested by other MB owners for VMI and the camera to connect to:
https://*****************/mercedes-b...in-motion.aspx
Old Jul 24, 2021 | 11:49 AM
  #132
Wetdogleader's Avatar
2001 CLK320 Cabriolet, 2012 Viano
Rear View Camera
Hi, I have read all that has been posted with regard to fitting a rear view camera to the NTG 2.5 and am still none the wiser. I have a camera fitted to my 2012 Viano but have had to wire it through a separate screen in the mirror as I could not get the Comand to see it.
I purchased a Star system a couple of years ago and found the step by step instructions as to how to enable the Head Unit only recently.
Plugged in the SD and followed the instructions and low and behold it all worked, but still ...nothing.
Does anybody have any idea if I have missed a step? I completed the change of enabling the rear view camera and it asked if I wanted to send the change to the module and after about 2 seconds it said 'done' . but still no sign of the camera or even a black screen as I have not yet connected the camera to the head unit......or is that the problem.
Rear view camera is still not there as an option on the system menu.
Old Jul 24, 2021 | 11:58 AM
  #133
Mackhack's Avatar
No camera plugged in no picture. If done right it will automatically switch to the camera view with a black screen and some text on the upper edge warning you about your surrounding when I’m reverse.
Old Jul 24, 2021 | 12:02 PM
  #134
OK Great and thanks for the quick reply. Tomorrow I will attach the camera and see what I've got.
Old Jul 25, 2021 | 06:28 AM
  #135
OK so I have played with it again today and connected the camera. Still absolutely nothing, zilch, nada.
I checked again with the SD and for some reason it had gone back to not installed, so I reinstalled it again came out of it and went back in and it was showing installed.
Ignition on, select reverse and still nothing it does not switch screens, you are still looking at the radio screen or whatever was there before.
I feel that there should be some sign of a change, the message check your surroundings etc is generated by the car not the camera I believe. I would expect to see the message and a black screen with no camera attached, would that be correct.
I did not restart the ring....whatever that is, and have also read that it can take up to 4 hrs for these changes to take effect. Is that correct
Old Jul 25, 2021 | 09:23 AM
  #136
Mackhack's Avatar
Incorrect. It’s immediately available if done correct.
I have coded numerous of these and never had an issue like you.
Old Jul 25, 2021 | 09:57 AM
  #137
Just lucky I guess! One thing that has come to mind is there is no reverse camera option on the HU. I though that once it was coded the option would appear on the menu. Is that how it works or is my Comand the only one that wont accept a camera?
Old Jan 2, 2022 | 04:20 PM
  #138
BobCT's Avatar
SL550 2012
backup camera - Fakra connection
Guys, I know this is an old post but stumbled across it in researching adding a back up camera to my 2012 SL550 (NTG 2.5). Question on the Fakra connectors and color? I have a green Fakra port that's unused, the yellow and blue are in use. Does it matter WHICH Fakra port I use on the Comand unit?
thanks
Bob
Old Jan 3, 2022 | 10:00 AM
  #139
e350forme's Avatar
fleet
thanks
Bob
most likely yes, unfortunately cannot offer more help sorry Bob. Worth figuring out. once in a blue moon I put it out of reverse back into drive and it keeps the camera on. rare
Old Jan 3, 2022 | 10:02 AM
  #140
e350forme's Avatar
fleet
get the best quality camera you can find so it does not poop out. also, drilling a small hole is not a big deal, worst case scenario you patch it over with epoxy and black ink. drilling and installing camera is CORRECT way to mount camera instead of the "pop in license plate bulb" style ones.
Old Jan 9, 2022 | 06:38 PM
  #141
mohamedkhattab's Avatar
W211 e240
NTG1 backup camera
Hello Gents and greetings from Cairo, Egypt.
It’s been taking me a while searching for similar subjects and I have my 2003 e240 which had the audio tapes comand and then I retrofitted it NTG1 with green fakra as my car is equipped with the fibre optic cable.
I would be indeed grateful if you can guide me how to enable the backup camera and I have no problem to manually press the video button to switch to the back up camera.
Any support will be truly appreciated.
Thank you
Old Jan 23, 2022 | 05:57 PM
  #142
BobCT's Avatar
SL550 2012
good advise, appreciate the replies!
