E-Class (W211) 2003-2009
Slow Fuel Fill and Foaming on CDI
Old Sep 26, 2010 | 02:24 PM
TPAbnz's Avatar
2017 E300W
Went to fill up today and diesel barely trickled in, lots of foaming, and it sounded like it was gargling! Fuel bubbled up to the top of the filler tube and slowly trickled to the tank. Took about 15 min. for 12 gal. Any thoughts on the problem? Is there some sort of valve between the filler tube and the tank?
Old Sep 27, 2010 | 09:51 AM
kenikola's Avatar
2005 E 220 CDI
Just want to chime in saying I have the same problem. From time to time it is very hard to put diesel in the tank. Sometimes I just have to give up, driving away from the pump having only managed to fill about 10-20 liters (3-6 us gal). The problem does seem to be that the diesel is foaming. This happens in very low ambient temperatures as well as warm weather. What could be causing this?
220 cdi wagon
Old Sep 27, 2010 | 11:38 AM
06e320cdi's Avatar
2008 ML320CDI
Personally I would relate it to the pump. They could have changed filters on the pump and there was an air leak, so in essence you were pumping foam instead of fuel. Next time this happens try a different pump or station just as a test.
Old Jul 16, 2013 | 10:01 PM
dieselophile's Avatar
'06 E320 CDI, NAV/HK Sound/Xenons/KeylessGo, '05 997 Carrera cabrio, '08 R320 CDI.
Same issue- slow fill and overflow fueling up.
I had the same problem today filling up my '06 E320 CDI and was unable to get a full tank of fuel in, I was in a hurry so I left after an incomplete fill (~12 gallons took me forever, with multiple interruptions), and closer to home went to another gas station where I was able to fill without any problems whatsoever (felt relieved that it was not a problem with my tank/fuel sensor etc). I believe theres a filter (???charcoal filter) leading to the fuel tank that backs up when the fuel is foamy. The simple solution is to fill at another pump.
