E-Class (W211) 2003-2009
Navi Gurus Question
Old Nov 1, 2010 | 10:19 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Navi Gurus Question
I added a Comand unit and Nav drive in my 2003 E55. All the NAV functions works, but the only problem I am having is when I press the MAP button nothing happens. it doesnot pull up the current location on the car.
Any tips on what could be wrong?
Old Nov 1, 2010 | 11:01 AM
Mackhack's Avatar
After you put the nav drive in and checked that everything works, did you drive around for about 20 minutes to calibrate the system?
Make sure you have enough satellite signals. If your system shows no satellites your GPS antenna might be defective.
Old Nov 1, 2010 | 11:03 AM
shardul's Avatar
yes i drove around for a week. the screen shows 8 satellites in Texas. like i said all nav funtions like route guidance etc etc work. But when i press the MAP button nothing happens.
Old Nov 1, 2010 | 01:53 PM
SoCal208's Avatar
12E350, 12ML350, 08C350
I thlink you have to go to MB dealer (use SDS) to set NAVIGATION exist on your car in order the MAP button to show (I remember that it was done a few years ago when I put OEM Navi to my W208). MB dealer charged $100.00 to roll their SDS computer out, set it on my car, I hear that some dealer do the SDS without charge, but I was not the lucky one. Regards.
Old Nov 1, 2010 | 02:08 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Make sure that you have all updates as well. It could be that your DVD needs those updates to function. There have been posts on here discussing this.
Mackhack's Avatar
I told him that already. There are 2 things one has to set. The Cluster Display to have navigational output like the compass and routing information and to tell the car that there is a new MOST device in the ring. If that is done and the button still doesn't show any response my best guess is that the button is defective.
Old Nov 1, 2010 | 02:29 PM
shardul's Avatar
will try that also.
thanks
Old Nov 12, 2010 | 01:41 PM
Mackhack's Avatar
Hey shardul,
I found something out. PM me and I'll send you something your way!
