2007 E550 E350 Sunroof operation
I was wondering if the operation of my power tilt sunroof is operating correctly.
My question is when I close the sunroof with a single push of the button it gets to within 1.5 inches of closing it then reverses and opens to the half way position and stops. From a closed position when I push the button to open the sunroof it opens fully. I can fully close the sunroof no problem if I hold down the button. I am wondering if this is normal operation. My car is a 2007 E550.
1 Post
10 Cayenne GTS, 07 Porsche 911 Turbo
2015 ML 350
I checked the rails and they are very clean, I guess the one touch express open/close part isn't working properly. It opens fully with one touch but express close part is the problem. I believe there is a way to reset or synchronize the sunroof. Anybody know how to do this?
the manual says to pull fuse for sunroof and then reinsert fuse. The tilt sunroof up and hold for 1 second. I can not pull the fuse because I can't find the fuse chart anywhere. I located two fuse boxes. One on the drivers side engine compartment by the firewall and one in the trunk, neither has a fuse chart. Ugh. Any ideas?
