E-Class (W211) 2003-2009
Engine Mount
Old Nov 15, 2010 | 05:49 PM
rontnak's Avatar
2003 W211
Engine Mount
I just changed both the engine mounts and the transmission mount. The transmisson mount was very easy. The engine mount is not difficult, just very time consuming. The time consuming part is you have to remove the exhaust from after the manifold to before the catalytic converters. After you remove the exhaust the engine mounts come out very easily. To reach the top bolt of the engine mount is is best to use an off set 16mm ratchet box wrench due to the limited space. Changing the mounts made all the difference in the world, the car runs very smooth.
