Motor sound like noise from the dashboard
When I open the driver side door, I am hearing the noise like motor sound. does anybody hear that sound?. I bought this one on feb 28, 03. Thanks in advance.
Does it mean that every E320 makes a sound when we open door ? Is this normal or needs to be fixed?
If you look at the manual, you will find that a number of things trigger the SBC system - if you open the door using the key or keyless-go; if you touch the brake pedal; if you place the ignition in position 1 or 2 etc.
