E-Class (W211) 2003-2009
Help please, xenon headlight driver side not working
Old Dec 12, 2010 | 10:35 PM
sharky's Avatar
Hi all
The xenon headlight on the driver side is not working and I thought it's the bulb so i bought a new set and changed both sides. However, it still not worked so swapped the the bulb and the connector (ignitor) on the passanger side and it's still not working. Please help....
Thank you very much
2003 E320.
Old Dec 12, 2010 | 10:40 PM
sinister55's Avatar
C55 AMG, BMW 535i, Mazda Cx-7, Nissan 240sx
Originally Posted by sharky
Hi all
Thank you very much
2003 E320.
It may be the wire that the ignitor connects to.
Also check wiring harnesses, they may come loose.
Old Dec 13, 2010 | 07:46 AM
sharky's Avatar
How do I check if the wire that connect to the ignitor is good or bad? and Where is the harnesses located?
Thank you very much.
Old Dec 13, 2010 | 03:31 PM
sinister55's Avatar
The end of the ignitor wire that leads to the back is the harness. The place where the bulb fits in should be clean and free of rust. Mine for some reason was alittle rusted and enlarged so i had to squeeze the leads closer together for ignition.
Old Dec 15, 2010 | 03:45 PM
sharky's Avatar
I dropped off my car at the Mercedes dealer to have them check it out and they said the headlight module is gone and it costs 550 for the module + labor = 1050 total. Is it possible to do it yourself?
