Retrofit OEM trailer hitch possible?
There is no US-specification (receiver) OEM trailer hitch.
These only exist for ML, GL, G, and R-class.
You could fit the Euro-spec hitch, which has a fixed 50 mm ball (slightly less than 2 inches). If this comes in a kit, it will come with wiring for Euro-spec electrics, too (13-pin). Procedures are all in WIS, for example AR31.10-P-800TT.
The standard "U-haul" connector has 4 and the Pollak plug fitted to my GL has 7.
The Euro system includes wiring and plug connectors for rear fog light, turn signal/brake bulbs separate, and backup lights.
I think the Euro system even has an interface with the car's burglar alarm.
Former Vendor of MBWorld
some slow@$$diesels
I installed several original fold-away (european) trailer hitches in US W211s...def possible and very well doable
you just need to be aware that you might have to modify whatever gets towed to make it work with the european ball and wiring - or just stick to the mercedes bicycle rack
greetingz,
greetingz,
greetingz,
greetingz,
some slow@$$diesels
you will have to change the wiring on the trailer - the european socket is a 13 pin socket - every bulb gets it's own wire and the instrument cluster of the car will even tell you when one of the trailer bulbs is blown
and as mentioned before - the alarm of the car will sound when the car is parked, locked and somebody disconnects the trailer
greetingz,
greetingz,
Thanks for letting me know about the sweet stuff
I know I couldn't meet you at your last CA trip. Wanda perhaps told you that I wasn't in SD during that time of your fall trip.
Do you have a new SoCal schedule for this year?
