E-Class (W211) 2003-2009
Help ! Xenon issues..
Old Jan 3, 2011 | 12:15 PM
dsm2925's Avatar
W211
i have a e500 with factory xenons. i do not have bi-xenon..
i had a xenon bulb out so purchase a set of two because i thought it would be smart to have aspare around.
So i changed the bulb but still doesnt work. so thought maybe the black box that goes behind the bulb was bad. So put the black box behind the the other headlight that worked good and it WORKED.
So what could it be? can it be the silver box under the headlight? When i turn the light on i hear a click from the headlight so it makes me think its working..
P.S - i also swapped bulbs too.
Can something be loose?
Old Jan 5, 2011 | 03:09 PM
dsm2925's Avatar
W211
Help!
Old Jan 6, 2011 | 12:09 PM
health services's Avatar
I don't understand, you found out that putting the good black box from the other side fixes the problem, that is your problem right?
Old Jan 6, 2011 | 12:25 PM
dsm2925's Avatar
W211
i found out that the black little box is good because i tested it on the other side.
Old Jan 6, 2011 | 12:40 PM
Sorry, it was not clear which box was switched to which side. And of course you check the headlight fuse for the bad side...
Old Jan 6, 2011 | 07:45 PM
Dexion's Avatar
03 E320, 03 Lexus RX300
I didn't know it was possible not to have Bi-xenon, are you sure? I thought my car did not either since my hi-beams where the city lights come on if I use the stalk, but to my surprise my xenon's flick up as well. So I have 4 hi-beams, lol.
Old Jan 6, 2011 | 11:20 PM
djrabbi's Avatar
EQS AMG, E53 AMG, GLE63s
i think all xenons are bi-xenons? lol
Old Jan 6, 2011 | 11:49 PM
charliele729's Avatar
09' E350 AMG Sport, 09' C300, 03' Honda S2K
Not all xenons are bi-xenons. Maybe for MB, bot not other manufacture.
Old Jan 7, 2011 | 08:44 AM
djrabbi's Avatar
thats what i meant....
Old Jan 12, 2011 | 11:59 AM
dsm2925's Avatar
W211
I still am not sure what is wrong..
Old Jan 16, 2011 | 03:53 PM
starbrite's Avatar
2004 E320
Yes, I had that happen during the summer. Replaced the bulb and it still didn't work.
Took it to an indy shop and they found that it was a loose wire.
Sorry I didn't ask which one or where it was.
Btw you always replace them in pairs, as a new bulb will be much "whiter" for the first ~100hrs of use.
Old Jan 16, 2011 | 10:31 PM
bmovegas's Avatar
'08 SL 550
Where did you get the bulbs; since I have 1 out also?
Old Jan 17, 2011 | 09:08 AM
dsm2925's Avatar
W211
i got a set from a friend for $50.
they are 12k
Old Jan 17, 2011 | 09:16 AM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
they are 12k
If you have factory lights they should be BiXenon. I think you have some half assed aftermarket Xenons. If the bulb is different than whats in there that may be your issue if not it could be the box you mentioned.
Old Jan 17, 2011 | 09:34 AM
starbrite's Avatar
2004 E320
I think you were asking me ?
Ebay-Click Here Factory bulb/4200k
they are 12000 K
Note: as the Kelvin temp goes up, light putput goes down.
+1, they may look cool, but don't perform as well.
Old Mar 1, 2011 | 02:44 PM
dsm2925's Avatar
W211
well ill be damed! i do have bixenons..
Old Mar 1, 2011 | 05:14 PM
XLR82XS's Avatar
2006 E500 4matic wagon
Don't go any higher than 6000K if you want to see the road well enough.
Old Mar 1, 2011 | 05:18 PM
03'55AMG's Avatar
AMG
Anything over 8000k is garbage IMO
Old Mar 2, 2011 | 12:08 PM
dsm2925's Avatar
W211
i just realized it. i got 12k and i do not like them.
Old Mar 2, 2011 | 12:09 PM
dsm2925's Avatar
W211
So anything higher- you will loose brightness?
